Author Topic: more problems p1700 code  (Read 2919 times)
martin42
« on: 07 April 2012, 10:45:11 »
Gearbox has been having pmt and threw the p1700 code up yesterday,what does it mean and how can i sort it out,going to do an atf change at end of month .
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: more problems p1700 code
« Reply #1 on: 07 April 2012, 11:17:20 »
got that code too p1700 (0) svs via can-not present mine says
« Reply #2 on: 07 April 2012, 11:23:52 »
Need to read the TCM ECU :y
If that comes back with Incorrect Ratio, thats a fair sign the oil is low, of the gearbox is badly worn (probably due to oil being low/abused for a long time).
martin42
« Reply #3 on: 07 April 2012, 11:35:55 »
Will pick up some atf and top it up for now  :y
« Reply #4 on: 07 April 2012, 14:36:15 »
Hope you get it sorted  ;) doing my atf when it gets warmer . Let us know how you get on with it  :y
martin42
« Reply #5 on: 07 April 2012, 15:40:31 »
I will do mate,picked up some atf  fluid while i was in bedford earlier,top up 2moro morning,nothing better to do lol   :y
martin42
« Reply #6 on: 07 April 2012, 18:03:07 »
as i was bored i decided to check fluid level,and i had car jacked up to max height on trolley jack on drivers side,removed bolt and atf poured out,im wondering if its been over filled,going to get gaskets and filter and do a atf change.
« Reply #7 on: 07 April 2012, 21:19:29 »
If the engine wasn't running, thats normal.
As said earlier, you need to read the TCM codes.
Steve B
  • Leicestershire
« Reply #8 on: 07 April 2012, 21:30:01 »
read tcm codes  what does that mean traction control module....or...transmission control module :-[
« Reply #9 on: 07 April 2012, 21:32:39 »
gearbox
