Author Topic: Heated Front Seats  (Read 2414 times)
autoelite
  • Peterborough
    • Omega 2.6 Elite
Heated Front Seats
« on: 09 April 2012, 20:55:29 »
Sorry if this has been asked before but here goes.
My front heated seats wont work at all. Checked fuse no 14 and all is fine but when I turn the switches on there is no lights at all. I have ordered some new switches to see if that fixes the problem but other than that is there any relays or any other areas that I should investigate.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Heated Front Seats
« Reply #1 on: 09 April 2012, 22:04:48 »
on mine there is one in the fuse bay a relay can hear it click then the light comes on the switch.
Solar charger fitted.
If not Broke dont fix it..
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #2 on: 09 April 2012, 22:22:14 »
Does sound like a power problem. Hopefully an easy fix  :y
« Reply #3 on: 11 April 2012, 01:42:00 »
Failed seats should still lite up the switch on the dash.
autoelite
  • Peterborough
    • Omega 2.6 Elite
« Reply #4 on: 11 April 2012, 13:26:20 »
No lights at all is there a relay read on here that mine has no relay but worth a check. Is it one of the relays in the fusebox or elsewhere looked online for its possible location and came up empty.
« Reply #5 on: 11 April 2012, 13:30:51 »
Check fuse #29
autoelite
  • Peterborough
    • Omega 2.6 Elite
« Reply #6 on: 12 April 2012, 12:33:49 »
Will give #29 a go but the report from vauxhall says fuses seem okay and that it would require further diagnostic tests but all is worth checking
« Reply #7 on: 12 April 2012, 18:48:23 »
Ignore anything Vauxhall, or "Vauxhall trained mechanics" say, they are universally clueless :y
Should add, most other marques are almost as bad, but this is a Vauxhall site...
Page created in 0.022 seconds with 20 queries.
