Pages: 1 2 [3]  All   Go Down
Author Topic: Tyres, what's quieter than sc3's?  (Read 9980 times)
Re: Tyres, what's quieter than sc3's?
« Reply #30 on: 20 April 2012, 22:24:20 »
Unfortunately it looks like I'll be swapping the Alphas to the rear to prolong the life so things could get interesting ::)
    • 530D M Sport, 330i Coupe
« Reply #31 on: 21 April 2012, 18:11:26 »
On the subject of SC3's I note there are at least two versions, standard and stengthened sidewalls, giveaway is the bigger rim protection lip and the writing on the tyre and speed rating.
« Reply #32 on: 21 April 2012, 22:19:55 »
Strengthened side walls? Or Rim protection? Anyway, that's what I have. 93Y iirc.
« Reply #33 on: 22 April 2012, 00:05:14 »
Sorry wrong description, should really have said 'load range', there is an SL and an XL rating.
I believe it's to do with the ply rating and it relates to standard load and extra load?
« Reply #34 on: 22 April 2012, 00:10:15 »
Stiffness of the sidewall ;) I prefer XL (normally about 97 I think) as it's a stiffer sidewall so less flex, but that's on standard elite wheels... On a reduced sidewall depth on 18's I would probably go for standard like Gayboy has :y
« Reply #35 on: 22 April 2012, 00:19:45 »
Yes have XL rated SC3's on the rear and SL rated SC3's on the front of my V6, from a visual perspective the rim protection is more pronounced on the XL's.
Tonights disaster is a screw in the 1/4 worn Dunlop SP Sport Maxx on the back of the DTi.  >:( Wouldn't have minded the front as there's only a few 1000 left on them... so now I need to buy four tyres....  Could really have done done without spending that money this month. Think i'm going to go with either Toyo T1R's (Had these on it when I got it and they suit it well) or possibly Kuhmo E39's or Accelera Alphas.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #36 on: 22 April 2012, 11:45:46 »
If the screw is in the tread area can't you have it repaired ???
other rides
« Reply #37 on: 22 April 2012, 11:57:36 »
Yep it's in the tread, but i was under the impression you couldn't have a Z rated tyre plugged / repaired?
« Reply #38 on: 22 April 2012, 13:45:15 »
I have done before. Plays on your mind though.
« Reply #39 on: 22 April 2012, 16:53:57 »
If it can be repaired then i'll probably do that as it's got about 6mm of tread on it and is matched to the other side. Even if the pair end up as spares it will at least buy me some time as the fronts really need doing....
Popped a pair of 9090's on spare wheels on the back for tomorrow, just about managed to dodge the rain!
« Reply #40 on: 22 April 2012, 16:57:49 »
Can be done, but as with any tyre, once repaired it "loses" it`s respective rating
« Reply #41 on: 23 April 2012, 22:21:26 »
Repaired today, hopefully that will buy me some time as I need to get a Geo done and the other two tyres replaced.
Pages: 1 2 [3]  All   Go Up
