Author Topic: Dash fault  (Read 2193 times)
Dash fault
« on: 14 April 2012, 11:08:17 »
I have a mate who's got a problem with the gauges on his 2.6 CD. Basically none of them work, the fuel, temp, rev counter and speedo are all dead but all the warning lights and MID are ok. I told him to give the assembly a push back to make sure they are seated properly but it hasn't worked. Anyone had the same problem or any ideas?
TIA :y
Re: Dash fault
« Reply #1 on: 14 April 2012, 18:27:44 »
cant check wiring diags, as I've been a prat, but any fuses worth checking ;)
Re: Dash fault
« Reply #2 on: 14 April 2012, 18:30:23 »
Worked out how to use rather computer. F12 feeds instruments but not warning bulbs. F12 also feeds MID and climate.
Re: Dash fault
« Reply #3 on: 15 April 2012, 10:45:27 »
Cheers TB.
The MID works fine but didn't ask about the climate.
Re: Dash fault
« Reply #4 on: 15 April 2012, 11:00:25 »
Fuse is fine ;)
Re: Dash fault
« Reply #5 on: 15 April 2012, 13:30:19 »
Would have to suspect the unit then.
