Author Topic: ABS ECU connector removal  (Read 1653 times)
shakooranwar
« on: 15 April 2012, 16:45:16 »
Hello
I'm having problem removing the ABS ECU connector. There seems to be a purple sliding latch.
Any know where what position the latch needs to be to remove the connector?
thanks
Shakoor
Re: ABS ECU connector removal
« Reply #1 on: 15 April 2012, 17:21:17 »
Push the latch towards n/s wing as far as it will go then it will release the connector
« Reply #2 on: 15 April 2012, 17:40:13 »
Careful not to break the "handle" part of the latch off - the Estate one was very tight, so I started it moving by slipping a knife blade between the latch and the casing and twisting gently.  A squirt of WD40 helped.
Page created in 0.035 seconds with 20 queries.
