Author Topic: Been busy on my 'other transport'  (Read 4726 times)
« on: 15 April 2012, 21:30:35 »
Finaly managed to get some shed space for my little hobby item and made a start today on cutting out some of the rot etc.
Here is a pic of progress, most of it aluminium (sides etc) but the fronts and rear are steel, hence the need to do a bit of welding!
waspy
Re: Been busy on my 'other transport'
« Reply #1 on: 15 April 2012, 21:36:14 »
Off topic.
Did you bid on those sockets I PMed you about A few months back?
« Reply #2 on: 15 April 2012, 21:38:14 »
Off topic.
Yes but didn;t win them
« Reply #3 on: 15 April 2012, 22:01:23 »
  Thats some project ... :o
Dr_X
« Reply #4 on: 15 April 2012, 22:04:22 »
WOW!!! your shed is pretty impresive too  :y
b4ndit
« Reply #5 on: 15 April 2012, 22:38:34 »
Nice project :y
hotrod222278
  • southampton
  • Omega MV6 (now dented)
« Reply #6 on: 15 April 2012, 23:31:31 »
Wish I had a garage, let alone one that big :o
« Reply #7 on: 16 April 2012, 00:14:42 »
What is it? apart from a train of course!  ;D
« Reply #8 on: 16 April 2012, 07:59:26 »
Its a 108 two car DMU set
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #9 on: 16 April 2012, 09:33:21 »
is it a derby built set per chance?
« Reply #10 on: 16 April 2012, 13:09:12 »
Yes, 1959 built. we have two cars, 63645, a Driving Motor Composite with lavatory (the one above, basicaly it has two Leyland 680 engines, first class, second class and a bog)
We also have a Driving Motor Brake Second, 53926 (Again, two leyland 680 engines, second class seating and a guards compartment)
So as per my preference, four engines (as opposed to the ones with a trailer which had only two!)
The Red Baron
« Reply #11 on: 16 April 2012, 13:21:07 »
i do like those old dmu,s. i take it you have a lot of work to do on them.
« Reply #12 on: 16 April 2012, 13:27:19 »
Yes and no.
The roof is all sorted on both cars.
This one requires plating front and rear (sides are aluminium) and the two engiens re-building. Interior needs cleaning (its very good inside), one air reservoir is holed and needs replacing/repairing, dynamo regulator has gone 'walkies' (might build a new one!) and an EP valve needs to be fitted (4th gear).
The other unit requires plating front and rear plus the interior sorting (which we have), both engines are fine though!
The Red Baron
« Reply #13 on: 16 April 2012, 13:58:54 »
Yes and no.
mmm not too bad then.
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #14 on: 16 April 2012, 15:01:32 »
That looks cool! Is it your own private train? Will you be able to drive it on tracks when it's finished?
TC and BnQ Trade holder.
