Questions for Stag 3.2 LPG owners please
Started by JamesV6CDX, 17 April 2012, 11:15:25
Quote from: TheBoy on 17 April 2012, 16:58:31
The KME and grey injectors do not cause lag on 3.2 Omegas, unlike the high rpm gearchange problems I've never managed to fully overcome on the 3.0 that has red valteks
That's exactly my issue. High RPM gearchange problems...
May just set it to flick to petrol at 5000rpm and forget about it!
Think my 3.2 has only hit 5k rpm about 4 times since I got it  ;D
Only used the S button once too  :-[
Hmmm, mine would spend most of its non-cruising life on petrol ::)
Quote from: tunnie on 17 April 2012, 17:20:35
Want me to try?
Quote from: TheBoy on 17 April 2012, 19:04:58
Want me to try?
Sure, while you have it, fix that relief valve spring  ::)
Quote from: tunnie on 17 April 2012, 19:28:32
Want me to try?
Have you not done that simple task yet :o
As said, I think we've pinned it down to the injectors. I'm not convinced the Vap was innocent but the KME is well overspecced for the job ;)
Also as said, KME Reducer and AC Rail and  there are no issues right to the red line :y I can confirm this because I'm back driving the Omega again for a while :y :y
Quote from: TheBoy on 17 April 2012, 19:30:46
Want me to try?
Nothing simple about it  :(
sassanach
Quote from: sassanach on 17 April 2012, 20:32:36
what are these "grey" injectors.
3ohm, look like the Valteks but branded AC or Autogaz and seem to work. Mine's on 2.3mm nozzles, 1.1 BAR and perfect to the redline every time :y
2.5mm and the idle is a bit lumpy ::)
sassanach
Quote from: Lazydocker on 17 April 2012, 20:34:57
No shit, Sherlock.
Teilo has gone awfully quiet again, I'll try to call him tomorrow again.
Quote from: TheBoy on 17 April 2012, 20:38:44
No shit, Sherlock.
Apologies to both you and another member... I've not had a chance to call him :-[ :-[ I'll try tomorrow
sassanach
i would like to try these "grey"injectors on the rangie, how much and where?
Quote from: sassanach on 17 April 2012, 20:45:01
mine were supplied via a company called Motogas, but Lazydocker has a contact (owner I think) there that does us good deals, although bloody hard to get hold of.  Try dropping Lazydocker a PM :)
