Author Topic: ALARMS SYSTEMS  (Read 2738 times)
stickman
  • Addlestone
    • Omega 2.5 CDX Estate
ALARMS SYSTEMS
« on: 17 April 2012, 14:55:39 »
HI CAN ANYBODY HELP ON THIS ONLY HAD MY OMEGA A FEW WEEKS AND THE KEY FOB PLIPPER HAS GIVEN UP AND THE ALARM GOES OFF OCCASIONALLY ON ITS OWN I SOLVE THIS BY TURNING THE ENGINE OVER TILL THE ALKARM GOES OFF. DOES THE BUTTON IN THE CENTRE CONSOLE WITH THE VOLUME SYMBOL AND MAN RUNNING AWAY TURN THE ALARM OFF BY PUSHING IT IN OR DO SOMETHING DIFFERENT. ALSO I NEED A STEERING IDLER ARM AND SOMEONE GOOD 2 FIT IN IN THE HEMEL HEMPSTEAD HERTS AREA ANY HELP MUCH APPRECIATED AS I AM DISABLED WHICH IS WHIY MY TYPING IS A BIT DEMENTED
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: ALARMS SYSTEMS
« Reply #1 on: 17 April 2012, 15:25:49 »
The button that you refere too bypasses the ultrasonic sensors inside the car but leaves the doors / boot / bonnet protected  :y
Re: ALARMS SYSTEMS
« Reply #2 on: 17 April 2012, 16:10:12 »
.... AND THE ALARM GOES OFF OCCASIONALLY ON ITS OWN I  .....
This is sometimes down to the alarm's bonnet switch being bent away from the bonnet, the bonnet heats up in the sun & lifts slightly from the switch ............. unplug it to test, if all is well it's the switch!  :y :y
PS TURN YOUR CAP LOCK OFF ............... It's rude to shout!  ;) ;) ;) ;)
stickman
  • Addlestone
Re: ALARMS SYSTEMS
« Reply #3 on: 17 April 2012, 16:27:34 »
THX PEEPS I GOT PARKINSONS AND CAN ONLY TIMPE WITHE LEFT HAND AND KEEP BASHING CAPS LOCK KEY SO LEAVE IT ON WILL HAVE A LOOK AT BONNET RELEASE SWITCH
Re: ALARMS SYSTEMS
« Reply #4 on: 17 April 2012, 19:38:40 »
it'd be better if you left it off.  ::) ::) ::)
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
Re: ALARMS SYSTEMS
« Reply #5 on: 17 April 2012, 22:37:13 »
Hi mate welcome try and switch it off if on here mate  :y
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: ALARMS SYSTEMS
« Reply #6 on: 18 April 2012, 08:05:01 »
Welcome to the forum my friend -
They are indeed a very helpfull, resourcefull and friendly bunch on here and can cope admirably with any typos and grammatical errors that may arise - many on here also do not use English as their native language either, and we manage with them also, so do not worry about your typing affliction, we can can cope with it if you can.
That said, there do seem to be two instances where people on here will get aggrieved, and that is either the use of TXT speak or the use of capital letters, so do please try to turn them off if you can.
Look forward to some good banter with you in due course.
PS - Alarm problem: Bonnet switch is No.1 culprit, followed by an ailing Powersounder as a very close second
Radio & Decoding Technician
www.dndservices.co.uk
