Author Topic: swap ccr600 to ccr2006?  (Read 3092 times)
Rich-K
  • West Yorkshire
« on: 18 April 2012, 13:03:38 »
I have a ccr600 with glove box mounted cdc3 (cd not working). Can any one tell is it possible to swap the complete sytem for ccr2006. Do I need any extras like adapters. Will the steering wheel controls still work?
Re: swap ccr600 to ccr2006?
« Reply #1 on: 18 April 2012, 13:22:39 »
Nope
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 18 April 2012, 13:24:18 »
CCR600 is a single DIN unit, CCR2006 is double DIN unit.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 18 April 2012, 19:10:10 »
electrically, it can be converted from 26 pin ISO to 36 pin Mini ISO, but as pointed out above, you are going to need to take an Axe to the dash, as they are different physical sizes
Radio & Decoding Technician
www.dndservices.co.uk
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 18 April 2012, 19:11:58 »
However, if you have a CCR2006, you can always retro fit the CDC section into the CDC3, making sure you retain the original vertical PCB form the original unit - Easy conversion !!
Rich-K
  • West Yorkshire
« Reply #5 on: 19 April 2012, 12:57:29 »
Thanks for the advice, I appreciate the units are different sizes physically. Would I be right in thinking the cdc from the 2006 will connect to the existing ccr600?
« Reply #6 on: 19 April 2012, 13:16:28 »
Yep, just a case of removing your CDC3 from it`s casing and replacing with a working one but as Dave says, you need to fit your vertical PCB to the replacement
