Pages: 1 2 3 4 5 [6] 7 8 9 10   Go Down
Author Topic: 3.0l headgasket stripdown started  (Read 40137 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: 3.0l headgasket stripdown started
« Reply #75 on: 01 May 2012, 21:16:02 »
Ps, has anyone got a close up of the crank pulley clearly showing the mark that should be at 6 o'clock when the cams are in the right place?
Looking at these pics I can't wait to strip ralf naked so i can see all this  :y
:o really.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #76 on: 01 May 2012, 21:19:44 »
:o really.
Well ''Ralf The Car'' as opposed to our very own sheep-loving welsh OOF member  ::) ;D
RIP Paul Lovejoy
The Red Baron
« Reply #77 on: 01 May 2012, 21:23:08 »
 :D
i do have more pics for you webby, when ive uploaded them. :y
Webby the Bear
  • Northampton
« Reply #78 on: 01 May 2012, 21:55:57 »
:D
Cheers mate, i find it really interesting so please do keep them coming.
Quick Q..... are the v6's ''Dual Over Head Cam''? I initially thought ''quad OHC'' due to the engine having 4 camshafts but i think it refers to camshafts PER BANK... therefore making it DOHC..... if that makes sense  :D
RIP Paul Lovejoy
The Red Baron
« Reply #79 on: 01 May 2012, 22:02:12 »
2 cams per head on v6. :y
Webby the Bear
  • Northampton
« Reply #80 on: 01 May 2012, 22:06:09 »
so is it DOHC or QOHC?  :)
RIP Paul Lovejoy
« Reply #81 on: 01 May 2012, 22:06:29 »
:D
Double Over Head Camshafts -DOHC - usually refers to the fact that the exhaust cams are on a different shaft to the inlet cams, as an old fashioned Single OHC would have all the cams on the one shaft.
As the V6 has separate shafts for inlet and exhaust it is referred to as DOHC even though there are, as you say, actually 4 cam shafts.
Quad Cam Shafts implies that each cylinder has 4 valves and each valve has its own camshaft.. :)
HTH . :)
« Last Edit: 01 May 2012, 22:08:21 by Entwood »
The Red Baron
« Reply #82 on: 01 May 2012, 22:20:52 »
heres a few for you webby.  :y
cleaned the front a little.
Webby the Bear
  • Northampton
« Reply #83 on: 01 May 2012, 22:21:38 »
:D
HTH . :)
That makes perfect sense mate thanks...
each ''bank'' of cylinders needs exhaust and intake hence DOHC because there are two per bank even though there are 2 banks  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #84 on: 01 May 2012, 22:24:34 »
Cheers again RB.... and sorry not hijacking your thread... this stuff just gives me a har....... gets me excited! :):):)
I take it that once the fuel rail and inlets are removed then it's just a case of removing the black plastic (with tose connected red gaskets) to expose the intakes on the head? :)
RIP Paul Lovejoy
The Red Baron
« Reply #85 on: 01 May 2012, 22:24:55 »
look at the phots above, inners are inlet, outsides are exhaust. :y
edit, yes, when alls thats gone off the top this is what you see. ^^
« Last Edit: 01 May 2012, 22:26:27 by The Red Baron »
Webby the Bear
  • Northampton
« Reply #86 on: 01 May 2012, 22:33:52 »
cheers mate  :y :y :y :y :y :y
RIP Paul Lovejoy
The Red Baron
« Reply #87 on: 02 May 2012, 19:40:31 »
a couple more for you webby, until my torx bit broke tightening the cam sprockets up.  >:(
« Reply #88 on: 02 May 2012, 20:25:51 »
I may have a spare male 50... want me to check? :y
If so it's yours..
The Red Baron
« Reply #89 on: 02 May 2012, 20:46:20 »
If so it's yours..
damn decent of you james.  :y
Pages: 1 2 3 4 5 [6] 7 8 9 10   Go Up
