Author Topic: EML light on permanently!  (Read 5675 times)
stuk50
« on: 18 April 2012, 21:43:14 »
Hi,
My first post here!
I have a 51 plate Omega Elite.
Over the past few weeks the EML light has been on. Computer says it is the Cats.
Have changed those. No change.
Changed cat sensors - no change.
Changed mass airflow sensor - no change.
Car seems to run absolutely fine - no problems at all with EML on.
Concern of course is if I get a real problem - how will I know?
I have come to the conclusion that it could be an electrical fault - but where?
I am not a mechanic of any sort but would appreciate some (helpful) advice.
I am not looking for - take the bulb out or get rid of the car!
Re: EML light on permanently!
« Reply #1 on: 18 April 2012, 21:48:09 »
Assuming its a facelift V6 ...
Pedal trick and post up the results
http://www.omegaowners.com/forum/index.php?topic=90581.0
« Reply #2 on: 18 April 2012, 21:56:39 »
What engine?
« Reply #3 on: 18 April 2012, 22:10:42 »
Welcome to OOF mate  :y
Would help if you confirm model, engine & year mate  ;)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #4 on: 19 April 2012, 10:26:20 »
And also where abouts you are, they may be a member close to you  ;)
stuk50
« Reply #5 on: 21 April 2012, 13:40:18 »
Hi,
Thanks for responses.
It is a Omega Elite Automatic petrol 3.2
Year is 2001 and I am in Fareham, Hants.
« Reply #6 on: 21 April 2012, 13:41:17 »
Hi,
As said, pedal trick and post the codes on here
« Reply #7 on: 21 April 2012, 14:24:03 »
Bet you get an 0430 code error....
stuk50
« Reply #8 on: 21 April 2012, 15:33:10 »
Hi,
Thanks.
I get -
10 4 2 10
10 4 3 10
Cheers
« Reply #9 on: 21 April 2012, 15:38:17 »
0420/0430
Afraid you wasted your money changing the cats mate. Have a read of this http://www.omegaowners.com/forum/index.php?topic=90613.0
« Reply #10 on: 21 April 2012, 15:44:26 »
Hope you kept the old cats, pattern ones are nasty  :(
stuk50
« Reply #11 on: 21 April 2012, 16:02:38 »
Hi,
Thanks for your response.
Guess I am not having a good day Tunnie! - Didn't keep the old cats!
Now need to find a man to try your (RobG) suggestion.
I will let you know what happens,
Many Thanks.
« Reply #12 on: 21 April 2012, 16:11:15 »
Hi,
Many Thanks.
Hope you didn`t throw them, worth around £70 each scrap
stuk50
« Reply #13 on: 21 April 2012, 16:21:44 »
Hi,
Told you it was a bad day they are gone! :-[ :'(
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
« Reply #14 on: 21 April 2012, 19:44:13 »
Hi,
Hi ya mate iv a code reader near to you if you want in in Eastleigh shame about the cats but we live and learn if you want any help with turning your eml turned off/codes read
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
