Author Topic: Quick PC Problem....  (Read 4017 times)
M16
  • Lancs
Re: Quick PC Problem....
« Reply #15 on: 02 April 2008, 23:23:45 »
Also shown here (see method 2)
http://support.microsoft.com/kb/318728
« Reply #16 on: 02 April 2008, 23:25:14 »
Had the same problem few weeks ago. believe me it works. Also this is the solution as published in the MCP 70-720 examination guide.
If you oot from the XP disk as you would when you do a fresh install if there is already a version on the harddrive it will give you a repair option.
Yup, fully aware of the repair processes. Should be after working with NT since 3.5, and using it since the initial 3.1 ;)
I would suggest if that fixed it, then a user with admin rights had deleted them.
Oh, and don't pay too much attention to the knowledge you gained to pass your MCP - MS training (except the infrastructure design courses) and reality are miles apart (hence why when I sit in on recruiting interviews, I pay no regard to MCSE).
« Reply #17 on: 02 April 2008, 23:27:16 »
Which confirms what I said - boot.ini. ntdlr missing is aways a fault in boot.ini. Esp if you read the circumstances of the OP moving the HDD between machines. It will be the boot.ini
Oh, and did I mention boot.ini? Coz it will be the rather boot.ini!
M16
  • Lancs
« Reply #18 on: 02 April 2008, 23:29:37 »
I know what you are saying but didn't want to go too deep into the whole process. Was just posting a possible solution. As to infrastructure Thats going to be my next exam which I'm not looking forward to.
« Reply #19 on: 02 April 2008, 23:34:04 »
Hope they ask you how not to do a link.!!!!!!!!!!!!!!!1 :(
M16
  • Lancs
« Reply #20 on: 02 April 2008, 23:35:03 »
Funny  ;D
« Reply #21 on: 02 April 2008, 23:44:27 »
The clue was in the post - moving HDD. The disk numbering will be screwed, hence making boot.ini invalid.  Wouldn't be the ntldr/ntdetect files missing, as it boots in one machine.
Obviously, shouldn't move disks like that, as all the wrong drivers, and if done properly (unlikely given the circumstances we know) the chipset drivers will cause a boot failure later in the boot sequence, once the kernel mode driver loads.
Infratsructure is pretty easy if you understand TCP/IP and assocaited technologies, esp DNS (which is dead easy, esp with Microsoft's half baked implementation).  Just the AD part to worry about.  IIRC, FSMOs aren't part of it, but GCs are, as is replication/ntfrs/sites and service/rdns. Not sure if WINs is in the 2003 one - it was in 2000 one. DHCP/DNS/Kerberos/PKI etc are all standard Internet stuff, and should be easy for anyone working in the industry.
Good luck with exam :)
« Reply #22 on: 02 April 2008, 23:47:45 »
To be honest guys I have no idea what you are talking about  :-[ Sounds very impresive though.  ;D ;D ;D
M16
  • Lancs
« Reply #23 on: 02 April 2008, 23:52:49 »
Cheers for that. Have just rebooked 70-290 (windows server 2003) after failing by 2% so gonna have another crack at that then onto windows server 2003 Network Infrastructure.
« Reply #24 on: 02 April 2008, 23:54:53 »
Ah, thats not good.
Its been a while, but IIRC, Server MCP covers Server and XP Pro? Which bit were your week on?
« Reply #25 on: 02 April 2008, 23:56:14 »
Totally agree, however a "fix" that sometimes works - about 75% - is to boot to the windows CD, work to the install screen where it says it has found a previous windows install, the choose "R" for "repair install" [note : this is different to the repair consol screen that goes to  DOS]
Windows will delete and reinstall many files from this point on AND rewrite boot.ini .. it works very well most of the time. Takes about 40 minutes. Then install the drivers for the new motherboard etc etc
as I said .. not gauranteed but about a 75% success rate, and keeps all loaded programs intact  .. :)
« Last Edit: 02 April 2008, 23:57:15 by entwood »
M16
  • Lancs
« Reply #26 on: 03 April 2008, 00:03:40 »
Had a few problems with Terminal Security Services
LouisCorney
« Reply #27 on: 03 April 2008, 01:06:27 »
Good luck, but swap the dvd drive over with CD, and build XP on the PC that the HDD belongs to is best option ;)
This sorted it, and some other niggling problems  :y
« Reply #28 on: 03 April 2008, 19:33:02 »
And quicker to rebuild from scratch ;)
Page created in 0.029 seconds with 16 queries.
