Author Topic: Brake squeal .  (Read 13231 times)
Brake squeal .
« on: 19 April 2012, 17:32:15 »
When reversing and braking ie off the drive im getting a brake squeal from the rear , the whole brake system has had a overhaul including replacement pins and squeal plates ...handbrake shoes and drum were rubbed down and cleaned . Strange  ???
Re: Brake squeal .
« Reply #1 on: 19 April 2012, 18:15:50 »
What rear pads fitted?
Are the hand brake shoes binding a fraction?
holtender
  • Suffolk
    • 2.5 CDX Facelift
Re: Brake squeal .
« Reply #2 on: 19 April 2012, 18:25:23 »
Did you apply any Copper Slip?
Re: Brake squeal .
« Reply #3 on: 19 April 2012, 18:34:20 »
Pads were ok , dont know what make they were though and shoes were adjusted to bind very slightly .
Copper slip applied .
Re: Brake squeal .
« Reply #4 on: 19 April 2012, 19:16:21 »
There ya go. Proof. Copper slip does not stop brake squeal. Ask TheBoy. He'll tell you the same. ;)
And ask Kai as well. Pads dripping in copper slip and squealing like a squadron of stuck pigs. Flying pig pun intended. ;)
« Last Edit: 19 April 2012, 19:18:45 by chrisgixer »
Re: Brake squeal .
« Reply #5 on: 19 April 2012, 19:22:51 »
So ill clean off all the copper slip .
What shall i replace that with ...normal grease or that white grease stuff  :)
Re: Brake squeal .
« Reply #6 on: 19 April 2012, 21:00:08 »
I always use copper grease, never, ever had squeaky brakes before this set. Guess who fitted them ;D
Re: Brake squeal .
« Reply #7 on: 19 April 2012, 21:27:53 »
Think ill try a new set and see how it goes  :y
Re: Brake squeal .
« Reply #8 on: 19 April 2012, 21:34:02 »
No idea Jammie  :-\ :-\ ........ any clues?  ::) ::) ::)
Re: Brake squeal .
« Reply #9 on: 19 April 2012, 22:51:00 »
Copperslip rules OK  ;)
Re: Brake squeal .
« Reply #10 on: 20 April 2012, 00:17:14 »
Copper slip has no place on brake systems! :)
Re: Brake squeal .
« Reply #11 on: 20 April 2012, 00:32:44 »
I think you're on your own with that theory.  ;) ;) ;) ;)
Re: Brake squeal .
« Reply #12 on: 20 April 2012, 00:40:58 »
Yep, and your all wrong!
Although I may concede it might make a slight difference of up to a week on very mild squeal cases.
There is absolutely no doubt it makes no difference to squeal on trade club pads. Proven. The end. You know it, I know it, accept it, move on! :)
Re: Brake squeal .
« Reply #13 on: 20 April 2012, 00:45:45 »
You have copper slip on your pads, they squeak like buggery.
I have no copper slip on my pads, as it has no place on braking systems, and they don't squeal. Prosecution rests. ;D
Re: Brake squeal .
« Reply #14 on: 20 April 2012, 07:44:32 »
Why do they squeal when braking in reverse though and not forward  ???
Pages: [1] 2 3 4  All   Go Up
