Author Topic: heated side mirrors  (Read 5412 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
heated side mirrors
« on: 19 April 2012, 21:47:43 »
hi all....n/s works great o/s dont heat up.... have a volt meter.. any ideas...ie; testing pins for voltage coming in at door socket..and then which ones..
Agemo
  • Cleethorpes
  • Insignia
Re: heated side mirrors
« Reply #1 on: 19 April 2012, 22:13:58 »
Hmmm, not sure what wires do what on that connector. I think I would carefully remove the glass, then test the two spade terminals.
Steve B
  • Leicestershire
« Reply #2 on: 19 April 2012, 22:17:07 »
yes. that does sound best way ...do i need to take mirror off first or does glass come off in situ...
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 19 April 2012, 22:18:59 »
There is a guide, but I think the glass comes out easily enough with it in-situ.
Agemo
  • Cleethorpes
  • Insignia
« Reply #4 on: 19 April 2012, 22:21:10 »
Steve B
  • Leicestershire
« Reply #5 on: 19 April 2012, 22:30:00 »
looks like job done from them pics....cheers agemo...
if i get 12v .its the mirror...if i dont.....well i think about that after cos im sure they will be on same fuse/relay
« Reply #6 on: 19 April 2012, 22:49:41 »
If theres no spade terminals, glass isn't heated  :( ::) ;)
davethediver
  • Blackburn, Lancs.
« Reply #7 on: 19 April 2012, 22:56:17 »
Cd doesn't have heated mirrors or mine doesn't if offside is a problem open window and wipe it clear ;D ;D ;D
P.A. Caron de Beaumarchais
Steve B
  • Leicestershire
« Reply #8 on: 19 April 2012, 22:57:31 »
cd does have heated mirrors they work with heated rear and got the marks on mirror glass...
« Last Edit: 19 April 2012, 22:59:35 by bigtimecube »
« Reply #9 on: 19 April 2012, 22:59:12 »
Its been known for people to replace a broken heated glass with a non heated one  ;)
davethediver
  • Blackburn, Lancs.
« Reply #10 on: 19 April 2012, 23:07:54 »
Pretty certain they didn't may be wrong and as dbug says may well have had glass changed?
Steve B
  • Leicestershire
« Reply #11 on: 19 April 2012, 23:08:55 »
davethediver
  • Blackburn, Lancs.
« Reply #12 on: 19 April 2012, 23:12:21 »
Looks like an omega wing mirror to me any other clues?
Steve B
  • Leicestershire
« Reply #13 on: 19 April 2012, 23:17:16 »
it has a line through it about 3/4 down and the other side has like heater mark on it..
i will look in morning and get back on this one... but im sure they are heated..gonna get glass off
« Last Edit: 19 April 2012, 23:29:33 by bigtimecube »
jimac
  • Newcastle upon Tyne
    • Vectra 1.9 CDTi [150] SRi
« Reply #14 on: 20 April 2012, 11:46:37 »
Yep, you're wrong.  ;)
