Author Topic: linux grub hard drive help required  (Read 1127 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 20 April 2012, 20:10:44 »
This is a continuation of my thread about my lappy killing hard drives.
I booted from a live disk yesterday and I could mount and read/write on to the disk. All the files were there too.  I think the grub mst be buggered but any grub command I tried didn't work.
I am calling on the OOF community for your expertese.  I only get an hour of internet access a day or 20mb (whichever is reached first) and the connection is poor and slow.
I could do with your help, as aways thanks in advance
Re: linux grub hard drive help required
« Reply #1 on: 20 April 2012, 21:17:16 »
could be a million and one things, from bootsector to disk corruption. Is grub in bootsector, or 1st partition?
« Reply #2 on: 20 April 2012, 21:46:33 »
« Reply #3 on: 21 April 2012, 15:32:23 »
Boot config tends to be pretty complex in Linuces these days but you'll normally find the config for grub spread around /boot/grub, /etc/grub and /etc/grub.d possibly.
Normally you can recover it by calling grub to rewrite itself into the MBR and wherever else it lives, using the original config on your non-bootable system.
Have a look at the man pages for grub-install and grub-mkconfig for a start.
If it comes to grub-mkconfig you will have to point it where your original /boot partition has ended up mounted so it can find the original grub.cfg or whatever.
If it's frequently getting trashed it might be a sign that wherever it's living on the hard drive is getting overwritten by something else, e.g. it's also a block allocated to a filesystem / swap.
EDIT: once you do get it to boot, see if there's an update-grub script and run it as root. This will make double sure that you have the correct grub config back.
« Last Edit: 21 April 2012, 15:34:43 by Kevin Wood »
