Author Topic: An engine Q from a tard  (Read 6435 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 21 April 2012, 18:08:26 »
Here's my mate's engine from his Pug 307.....
The engine is mounted differently to the mig..... i.e. i would say it's mounted sideways as the exhaust manifold is at the front. so is the transmission mounted sideways as well?
so if thats the case how does the driveshaft attach to the transmission?
As i said its obviously a retarded Q but not being a technician (yet) i have to ask at this early stage in my career  :y
RIP Paul Lovejoy
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: An engine Q from a tard
« Reply #1 on: 21 April 2012, 18:17:49 »
its front wheel drive web. :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 21 April 2012, 18:19:04 »
Yep  ;)
Its called front wheel drive  ;D
Gearbox bolts onto the end of the engine  :y
2 driveshafts.
Stick your head under the wheel arches and you will see them  :y
Webby the Bear
  • Northampton
« Reply #3 on: 21 April 2012, 18:34:07 »
riiiiiiiiiight, i told you there'd be an easy answer  ::) cheers folks.
so basically if its FWD then the engine will be bolted sideways and the transmission and engine to the wheels at either end.
if its RWD then engine straight with driveshaft going to rear wheels?
RIP Paul Lovejoy
bored bigyin54
  • south wales
    • black beast
« Reply #4 on: 21 April 2012, 18:36:30 »
you got it steve in one ;D ;D
« Reply #5 on: 21 April 2012, 18:39:53 »
4X4's can have engines mounted either way  :y
Webby the Bear
  • Northampton
« Reply #6 on: 21 April 2012, 18:41:55 »
Hey you gotta start somewhere ralf  ;D
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #7 on: 21 April 2012, 18:42:54 »
cheers tunnster..... is this where a ''transfer case'' can be employed: drivshaft to the rear, transfer case transferring power to the front also?
RIP Paul Lovejoy
« Reply #8 on: 21 April 2012, 18:44:32 »
http://lmgtfy.com/?q=front+wheel+drive+layout
That cheeky chappy bloke arron sent me a link like that  :P ;D  Cool  :y ;) ;) ;)
Dugga dugga  ;)
Webby the Bear
  • Northampton
« Reply #9 on: 21 April 2012, 18:51:43 »
Dugga dugga  ;)
cheers steve  :y
and ralf went.....
RIP Paul Lovejoy
« Reply #10 on: 21 April 2012, 19:02:42 »
Commonly known as "transverse" Steve ;)
I_want_an_Omega
« Reply #11 on: 21 April 2012, 19:55:06 »
I don't know what the current VAG lineup is like, but they used to have the engine mounted along the car, like an Omega, driving the front wheels  :o
I guess the gearbox must have been at the back and then down to the driveshafts?
Webby the Bear
  • Northampton
« Reply #12 on: 21 April 2012, 20:01:25 »
Transverse! I'll remember that. Cheers rob  :y
another silly q then........... if on a FW drive the axel from the passenger front wheel goes to the transmission... then where does the drivers front axel go to?
RIP Paul Lovejoy
« Reply #13 on: 21 April 2012, 20:06:46 »
This explains it in laymans terms Steve
http://www.mistertransmission.com/what-is-a-transmission
bored bigyin54
  • south wales
    • black beast
« Reply #14 on: 21 April 2012, 20:07:03 »
i started like you steve a long time ago didnt have a computer then ha ha
