Pages: 1 2 [3] 4 5 6 7 8 9   Go Down
Author Topic: Rear Wheel Bearing  (Read 34860 times)
Re: Rear Wheel Bearing
« Reply #30 on: 26 April 2012, 15:39:22 »
As I don't get home from work until 17:30 Mon-Wed ... and you're Nottingham if memory serves.. so 2 hours away .. I wouldn't get to you until 1930 at the earliest mon-wed, other days I can be there whenever.
You are doing me the favour so I'll fit around you!!
Reading your "previous" the bearing needs to be "frozen" for 24 hours ... it'll warm up somewhat in 2 hours, so would you be able to get it and freeze it ?? I'll happily paypal the money up front.
Appreciate the help  :y :y :y
EDIT :  Just finished putting it all back together and done a short run .. noise is the same.. no better or worse..  :(  (although the brakes seem to be better.. perhaps I need to strip down the offside as well .. when it stops raining !!)
« Last Edit: 26 April 2012, 15:41:00 by Entwood »
supersaw
  • Lithuania
    • 95' Omega, 2.0 16v + LPG
    • MappingTracking.com
« Reply #31 on: 26 April 2012, 16:46:20 »
OFF TOPIC
So it seems that omegas has 2 or more phantoms....
1. sunroof
2. strange noise on the back of the car...
 :D
Still, I'm waiting for my holidays and then I plan to inspect my "ding ding" sound/noise deeper  :(
Horsepower is how fast you hit the wall
Torque is how far you move that wall
sassanach
  • trowbridge
« Reply #32 on: 27 April 2012, 08:16:01 »
if your happy to go to nottingham  then fair enough, however if you want to take a trip to trowbridge at 5.00 pm today clutching a wheel brg then i will waz it in for you. :y
« Reply #33 on: 27 April 2012, 08:27:25 »
That's a fantastic offer  :)... As soon as Skurrays answer the phone I'll find out if they have a bearing in stock and let you know !!  I'll PM you my phone number in case you want to chat.
Very, Very grateful .. and the Master might be pleased as well :)
« Reply #34 on: 27 April 2012, 08:59:53 »
PM sent... no bearing in Swindon but apparently one in Trowbridge .. has been reserved in my name, so hopefully will pick it up on the way to you.
Very much appreciate the help  :y :y :y
« Reply #35 on: 27 April 2012, 09:03:34 »
Might be worth discussing replacing the other side sassanach, to be safe? :-\
« Reply #36 on: 27 April 2012, 10:07:41 »
Contact made with Sassanach ... job being done tonight.
Regarding doing both .. no bearing in Swindon .. just ONE at Trowbridge (hopefully with my name now on it) ... so there is a "limiting factor" as Sassanach puts it .. :)
Many thanks to all  :)
« Last Edit: 27 April 2012, 10:11:35 by Entwood »
amba
  • Medway towns
    • German V6
« Reply #37 on: 27 April 2012, 10:15:52 »
Some pictures of the "proceedure " would be very usefull for others if that is possible ?
« Reply #38 on: 27 April 2012, 10:30:32 »
I'll take a camera ... :)  Might as well try and be useful !!
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #39 on: 27 April 2012, 11:18:18 »
Just to add the bearings are different the estate one is slightly bigger. :-\
Hoof'land storeman.
« Reply #40 on: 27 April 2012, 20:29:06 »
First of all MEGA thanks to Sassenach for his time and skills this evening.
He disconnected drive shaft, removed caliper, removed disk/drum, then confirmed that there was a nasty noise from the wheel bearing. With a suitable selection of some odd looking, but extremely effective, home made drifts, pullers and the most amazing "slide hammer", the old bearing was out.
New one in, again with a selection of drifts and threaded rods and nuts to pull it in. Disc/drum onto the lathe to remove the corrosion around the lip, and all reassembled ... total time .. 1 hour 40 minutes and that included fetching various tools from around the workshop and the lathe time.
And then he refused to take anything for doing the job, and he's not a man to argue with when he says no........
So, once again, a HUGE thanks. I did take a few photo's that I'll put up later, but nowt like a "how to" as no-one would have the tools and bits and pieces he has !!!
Now the bad news........
The car was lovely and quiet for about 5 miles, then the noise started again, going from "faint" to just as noisy as before in about 2 more miles... :(
From the drivers seat it still sounds like its from the left rear, it starts at about 20 mph, braking/steering makes no difference.... I might be fooling myself but I'm starting to think that it is  less noisy on overrun/very light throttle than it is when under power.
So what could it be ?? The only rotating things left are the drive shaft or the diff ... :(
Really hacked off now, especially as the old bearing WAS noisy once everything else was disconnected, so it needed changing... but obviously was not the reason for the noise. :(
Any how  .... that does not detract from the excellent work of Sassenach.
« Reply #41 on: 27 April 2012, 21:12:36 »
Next Q
Drive shafts and diff
Are they the same on a 2.6 as they are on the 3.2 ??
As Brikhead is breaking a 2.6 with a reconditioned diff
http://www.omegaowners.com/forum/index.php?topic=102211.0
I'm wondering .......  :(
« Reply #42 on: 27 April 2012, 21:13:29 »
Fairly sure the diff is different :-\
« Reply #43 on: 27 April 2012, 21:16:35 »
« Reply #44 on: 27 April 2012, 21:17:51 »
Yep http://www.omegaowners.com/forum/index.php?topic=90453.0
All V6 driveshafts are the same
Rollocks .. :(
Thanks for the info  :y :y
Is it worth changing just the drive shafts ?? or do I try and find a diff and shafts together ....  :(
or how do I diagnose one or t'other ... :(
Pages: 1 2 [3] 4 5 6 7 8 9   Go Up
