Author Topic: Climate Control Issue ?  (Read 1320 times)
rsymes2k
  • Devon
    • 99 Omega 2.5v6 CDX
« on: 23 April 2012, 19:19:08 »
Hi All,
I have an issue with the climate control on passenger side...
Before you ask i've followed this...
http://www.omegaowners.com/forum/YaBB.pl?num=1196616207
However, mine was all connected including the arm etc, i've removed the motor and got a new one from the scrappies but fitted it and when I do the climate control reset procedure I can get the arm to reset to the normal position but when I modulate the temperature on the climate control unit the motor buzzes a bit and doesn't move, if I run the motor by itself I can see it spin 2-3rotations and stop. The gear mechanism/arm module is completely free moving and little resistance but both the motor fitted to the car originally and the one from scrappies just seems to buzz a bit without moving the arm...
Any ideas? Unless i've managed to pick up a naff motor from the scrappies also?
Help mucho appreciado!
