Author Topic: F/L 3.0ltr Elite saloon breaking. Z147  (Read 8835 times)
Re: F/L 3.0ltr Elite saloon breaking. Z147
« Reply #15 on: 26 April 2012, 22:06:21 »
or fit face lift everything else to match. Its the only sensable thing to do. ;)
« Reply #16 on: 26 April 2012, 22:14:30 »
Doesn't really work, and always looks crap - it picks up the worse of the PFL, and mixes with the worse of the FL.
twiglet
  • Norwich, Norfolk
« Reply #17 on: 26 April 2012, 22:23:37 »
Perhaps I could take them off for you in exchange for a good dollop of tech2ing at some point...  ;)
  • Auckland
    • Mazda MPV
« Reply #18 on: 28 April 2012, 20:03:00 »
Thanks Twiglet :y
The scraper, presumably, will only penetrate 2 or 3 mm from top and bottom - cant remember how big the tape is.  Guess its a job best described as 'fiddly' ?
Cheers
IIRC the tape is approx. 12mm thick.  You'll find that as you get started from one end, you will be able to get the scraper in square on from that end, and wiggle the handle up and down whilst applying firm, controlled pressure.  Patience is absolutely the key.  Lots of little breaks for a cuppa.  ;)  If you overdo it and slip, you WILL bend the trim, at that will be that.  :'(
Maybe a silly question but.. would the cheesewire that windscreen fitters use to cut the seal on bonded windscreens work as well for stuck on door trim?
twiglet
  • Norwich, Norfolk
« Reply #19 on: 28 April 2012, 20:20:31 »
Thanks Twiglet :y
Cheers
That's certainly another option Andy, but you would have to be so so careful not the snag the wire in the moulding, as it would go that like a hot knife through butter!  :o
« Reply #20 on: 29 April 2012, 13:42:27 »
Engine & box.............SOLD
Front bumper............SOLD
ABS pump & ECU.......SOLD
Teebee
  • Slough
« Reply #21 on: 29 April 2012, 14:09:33 »
Thanks Twiglet :y
Cheers
Or an even sillier suggestion, take a hot air paint stripper to the inside of the door before using the scraper, it might just loosen the glue a little.
« Reply #22 on: 30 April 2012, 19:25:33 »
All 4 doors PROV SOLD
« Reply #23 on: 30 April 2012, 19:27:52 »
This is off to the scrappy in a couple of days so any odds & ends shout. Ta
S/L shocks staying on car unless someone`s interested
twiglet
  • Norwich, Norfolk
« Reply #24 on: 30 April 2012, 19:59:30 »
Christ Rob, 5 days from the original ad to the scrappy!  That must be a record, even for you!!  ;D
I'll drop you a PM about those bits I wanted.  :y
« Reply #25 on: 03 May 2012, 18:00:28 »
CAR NOW GONE. Can admin please lock, thanks.
