Pages: 1 2 [3]  All   Go Down
Author Topic: Leaking Flat Roof.  (Read 8808 times)
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
Re: Leaking Flat Roof.
« Reply #30 on: 30 April 2012, 21:04:45 »
Hi Vamps, I have a double garage with a  workshop attached so the overall width is 30 foot and the depth is 20 foot approximately.  I had the main garage roof decking replaced  with new sterling board and then the whole area covered with the rubber membrane so the total cost was  relatvely high because of the area and limited access.  However the actual rubber itself would only have cost about £400 if I did it myself.  I have seen kits to do a standard single garage for around £120 so not too bad for the long life quoted.  There is a lot of information on the process on the web.
« Reply #31 on: 30 April 2012, 21:41:49 »
Thanks for that, ideally some of the boards should be replaced, need to consider some options...... :D :D
Pages: 1 2 [3]  All   Go Up
