Author Topic: No Hot Water or Heating  (Read 4157 times)
Marie
    • 2ltr LPG Estate
Re: No Hot Water or Heating
« Reply #15 on: 04 April 2008, 16:06:29 »
My dads a plumber/gas engineer Technician. runs his own ltd company.
it runs in the family ( well it did)
What is the problem? other then no heating and hoidioter?
and what system hav you got in the house?
I dont know  ::) ::)
Its not your heating so how are you going to know! ;D ;D ;D
« Reply #16 on: 04 April 2008, 16:07:20 »
I dont know  ::) ::)
Its the crossed out bit I was referring to...
« Last Edit: 04 April 2008, 16:12:34 by Mark »
Marie
    • 2ltr LPG Estate
« Reply #17 on: 04 April 2008, 16:09:50 »
I dont know  ::) ::)
opps LMAO ;D ;D ;D ;D
« Last Edit: 04 April 2008, 16:12:48 by Mark »
« Reply #18 on: 04 April 2008, 16:12:29 »
My dads a plumber/gas engineer. runs his own ltd company.
Timbuk lives in Salop so its probably  the latest in log fires in the middle of a room with a kettle over the top for hot water :D
« Reply #19 on: 04 April 2008, 16:13:59 »
Given that the heating at the unit comprises of two skips welded together with some holes in them...........I can quite beleave it!
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #20 on: 04 April 2008, 16:57:27 »
Timbuk
  • Telford
« Reply #21 on: 04 April 2008, 17:13:21 »
Well the answer is as follows. I wouldn't call a plumber as i used to be one,I did have to go in the loft because i knew what the problem was straight away, circulation pump was screaming its backside off so i thought, hmmmm, theres no water in there, bled the system and only got air , no water to be seen, so i thought thers a  blockage in the header tank or the ball valve is stuck. So up i go into the tiny loft with my lead light in hand ::) found the smal header tank for the heating system and hey presto its empty with the ball valve stuck open, rested my lead lamp on the hot water header tank and watched it do a neat dive straight in ::) Electricity, hot bulbs and water are not the best of mixes, so with a loud bang, i was plunged into darkness  and i mean darkness as it was 11.45 pm and it knocked out the consumer unit, try crawling through a poxy loft in the middle of the night with no light :-[. Fortunately i didn't fall through the loft and yes i did fix it easily enough, but the correct answer is
I MADE A COMPLETE ARSE OF MYSELF BY DROPPING THE LEAD LIGHT INTO THE TANK :-[ :-[ ::) ::)
« Reply #22 on: 04 April 2008, 17:16:23 »
At least you were not HOLDING the lamp at the time ... that would have been a shocking mistake .....   :)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #23 on: 04 April 2008, 17:27:04 »
Could you do it again so Daz and me could video it for posterity? ;D
TuBy's new whipping boy.
