Pages: 1 2 [3]  All   Go Down
Author Topic: mv6 suspension vs lowering springs  (Read 14024 times)
Re: mv6 suspension vs lowering springs
« Reply #30 on: 02 May 2012, 21:06:10 »
Interesting.. I'm very tempted to upgrade my Westfield from 15" wheels to 13" wheels to improve the handling. ;)
Will there be any room left for the brakes, or are you just not bothering with those? They are unsprung weight, after all.. ;) ;D
Kevin Wood? Brakes? On a Westfield? Why?
Our Mr Wood prefers to use grass banks, and central reservations to slow down ::)
Ooooh he won't thank you for that one.. ;D
« Reply #31 on: 02 May 2012, 21:28:19 »
Bugger, and he knows where I live  :-[
;D
GmasterT
  • Cambridge
  • does that drifting thing...
« Reply #32 on: 02 May 2012, 23:19:42 »
Mv6 stuff seems to handle nice, very controlled. Pi's are softer with similar roll but lower, not as steady. Weistecs are good, similar stiffness to mv6 buy I was running wagon versions on a saloon, eibachs on now which are ok, similar to the weistecs to be honest. All the lowering springs are around 35mm from standard, if there was a shorter mv6 spring I'd run that though I think although the eibachs aren't far off, next step will be cool overs anyway
i260
  • Newport, South Wales
« Reply #33 on: 03 May 2012, 00:19:13 »
It is not just the spring that affects the ride height - your choice of shock absorber will play a part too. For example, running the Eibach spring with Bilstein B4 will ride a little heigher than with the B8 as the B8 is a shortened body for lowering springs whereas the B4 is designed for a standard height (although will work with up to -30mm) and will be trying to hold up at a standard height. Sililarly, if you are going to put lowering springs on with your 100k oem shocks then the end result is anybodys guess but the ride will be a bit squiffy and you will have missed a good opportunity to do a good job.
Good luck whatever!
Saab 9-5 Aero 260ps
GmasterT
  • Cambridge
« Reply #34 on: 03 May 2012, 10:28:45 »
Lol, it drifted around the longest track corner in Europe at the top of 4th gear ok ;)
Also have polys at the front and I know they are not the shocks it left the factory on from the police repair and service report. At the same time, I was never going to go mad with it as it clearly does the job I want it to do...
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
« Reply #35 on: 03 May 2012, 13:49:35 »
Awesome pic btw george!! shame no body has a camera when im hooning mine around!!  :'(
Defo got to come down soon mate & as yet no body has fully confurmed what omega uses a 3.45 diff....
"Kennny" rem if you run the 19" snowflakes off an astra vectra or zafira you will need a 5-10mm spacer & longer bolts due to the offset the front wheel drive cars run, the tyre will poss rub the front struts & your tyres will last under 10miles! Not good,
Beard
  • West Midlands
    • Vauxhall Omega
« Reply #36 on: 28 May 2013, 22:19:14 »
Hello; does anybody know how to change a broken rear spring suspension on a vauxhall omega 2002 2.2.
need to know ASAP as in need of urgent repair
thank you
« Reply #38 on: 28 May 2013, 22:38:34 »
thank you
Hey mate, you should really start your own thread, not keep posting the same stuff on other peoples threads.  You'll only piss them off  ;)  It's called thread hijacking!!
« Reply #39 on: 28 May 2013, 22:45:02 »
thank you
 ......... and just ask your question on the one thread, not carpet bomb the place  ???
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #40 on: 28 May 2013, 22:50:31 »
thank you
Especially when the threads are OLD!
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #41 on: 29 May 2013, 11:23:52 »
thank you
Beard,you have pm although RobG has already posted the link you need :y
other rides
Pages: 1 2 [3]  All   Go Up
