Author Topic: wont start  (Read 5557 times)
holtender
  • Suffolk
    • 2.5 CDX Facelift
Re: wont start
« Reply #15 on: 01 May 2012, 22:42:14 »
I did one last week on a 2.5, I think I payed £68 for a genuine part, but they had to order it in and there is a link on here explaining that there are two types of crank sensor on the 2.5 so  if you have a 2.5 make sure you get the correct one.
Simple job to do, just unplug one end and use a Torx screwdriver on the other end.
The hardest part of the job is locating the crank sensor, if you take off the N/S front wheel you will see the oil filter and the sensor is just above it held in by a torx bolt.
« Last Edit: 01 May 2012, 22:45:08 by holtender »
Re: wont start
« Reply #16 on: 01 May 2012, 22:51:33 »
As above but follow the guide regarding routing of the cable.... or the exhaust heat will damage it and you'll be replacing it again very soon !!
aiden
  • middx
    • omega cdx estate
Re: wont start
« Reply #17 on: 02 May 2012, 11:44:49 »
 recieved new sensor i'll try and fit it today if the rain keeps off, Aiden
Re: wont start
« Reply #18 on: 02 May 2012, 14:02:04 »
 :y :y
Re: wont start
« Reply #19 on: 04 May 2012, 16:55:15 »
Any luck?
As this is such a quick job, (eg, 15 mins) I could potentially call in tomorrow PM, as I may be near the area, weather depending. Drop me a PM if you need any help.
I'm hoping you've got it sorted, though  :y
aiden
  • middx
    • omega cdx estate
Re: wont start
« Reply #20 on: 05 May 2012, 12:48:38 »
not done it yet, just recieved set of torx sockets, try and do it today :
aiden
  • middx
    • omega cdx estate
Re: wont start
« Reply #21 on: 05 May 2012, 14:53:14 »
all done and running took about 20 mins, many thanks for your   :y help. Aden
