Author Topic: Best tool to cut through a suspension bolt (which isn't a grinder..)?  (Read 10083 times)
I had a similar issue removing a bolt from the front suspension last week. I got a blowtorch on it for about 5 mins, heated it up.
It was enough to break the rust and get a splitter on the joint.
Try a bit of heat ?
Is a valid idea ;) I set it on fire yesterday though to no avail :( Well, not the wishbone itself, obviously ;D Got it as hot as I could with a blowtorch though and the rubber shock bush caught fire (my does that ever pong in a garage!).. not really as hot as an oxy torch would have got it though - I recon it might have shifted with that..
But, since oxy torches scare the bejezus out of me (and I don't like the idea of storing two big tanks of flammable gasses by the house ;D) - saw it is!
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Try a bit of heat ?
I doubt that the bolt is hardened anyway,it'd be too brittle to absorb shock,probably just toughened which the airsaw will cut,I normally use normal hack saw blades cut down to a suitable length.
other rides
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
Try a bit of heat ?
Sometimes it does take a few heat cycles to break the joint, but it sounds like you're down to a bit of elbow grease with a saw.
However, if you dont like the idea of ox/da what about a plasma cutter  ;D
Didn't think of cutting hacksaw blades down - could have saved myself the cost of a set of air saw blades.. still, I'll remember that for the future! :)
Ooh a plasma cutter :y I'd have cut the whole car into little bits by now if I had one of those..  ;D
markrnorton
  • Essex
Thats what i need eventually to get rid of the v6's bodyshell !! make things a whole lot easier
  • Chatham, Kent
    • Ghastly 1.0l Focus
Actually, it's a pain to use a plasma cutter to cut up an entire bodyshell; they're not good on double skinned panels, and box sections take a fair bit of effort.
Best thing is a 9" angle grinder! You'll have a bare shell in four pieces in about 5 minutes even if you're using a £50 grinder from B&Q. Plus, they're not bothered by the odd bit of trim/wiring/bolt that you forgot to remove.
I can safely say that it was a long, tedious job to get through one side of the pivot bolt with the air saw! Used about five blades doing it, too..
And after all that, I still can't split the two halves of the damned wishbone. T'other side came off so easily, too! Grrr.
Now formulating a plan to get the other half of the pivot bolt off .. maybe I'll invest in a 9" grinder next ;D
mantahatch
I got a 12 petrol disc cutter and steel cutting blades here if you like. Not to many years ago I cut up a Opel Manta, reduced the whole thing down to bits big enough to fit in 5x4 trailer. Good fun. Found the hardes bit was the gearbox tunnel as awkward to get the grinder in properly.
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
is the bolt like the pinch bolt on the omega-wishbone to strut balljoint? if so then i hit a masonry chisel into the gap to try and free it off a bit, got a bit warm but that and a balljoint splitter got it off and regarding the pinch bolt its self, take the brake caliper and carrier off, turn the steering then get a suitable bar and a big hammer in it :P
V8!!!!
Nah it's one reaaaly long (12" or so) bolt that runs through the pivot axis of both rear bushings, like an axle.. which, unfortunately, you can't actually get out without removing the steering rack (because the rack is in the way of the bolt sliding out backward) - and on the V12, also the exhaust system (because the CATs are in the way)..
So on the other side we freed off the front half of the wishbone (it's in two pieces) and got that off, then pounded the bolt back just far enough to get the grinder in and free the rear half.
Sadly on this side the pivot bolt just isn't budging despite the pounding, and although I've ground through the front half of the pivot bolt so the front wishbone half is free, I can't get the two halves unstuck from one another ;D and can't get the grinder in to free the back half because the bolt won't pound back any...
Bigger grinder will probably do it as the disc will go in without the body of the grinder hitting the wishbone.
Success!
Van Helsing
    • Opel
Glad you got it sorted, but that workshop / garage looks far to new and clean compared to mine..... :D :D :D
 ;D ;D That's because it is! ;) Only had it built last year  :)
