Author Topic: Replacing brake pad advice and which breaker bar  (Read 5041 times)
Re: Replacing brake pad advice and which breaker bar
« Reply #15 on: 03 May 2012, 15:33:16 »
Personally, I never use "spray" grease ... several reasons...
It goes everywhere
It is very "runny" to allow it to spray
You can't just put a "blob" on as the carrier gas spreads it
Impossible to use in a grease gun (yes, I still have one and use it occasionally !!)
IMHO it is far better to by a small "tub" of grease and apply it either with a small paint brush or your fingers.
Just my thoughts .. nowt else .. :)
I agree, though the lithium spray grease is very good at lub'ing a Smart's clutch actuator  ;) ;)
SMD
  • London
    • :( nowt
« Reply #16 on: 03 May 2012, 16:00:59 »
aaron, is this the stuff that can be used for sliders?
http://www.ebay.co.uk/itm/18g-Castrol-Red-Rubber-Grease-Brake-Caliper-Fluid-Handy-MINI-TIN-/130679593752?pt=UK_Hand_Tools_Equipment&hash=item1e6d1c5b18
Can i use this stuff on back of pads and edges of calipers?
« Reply #17 on: 03 May 2012, 17:04:24 »
Funnily enough, that's why I have a can too.. not for a Smart but for the MR2. Squeak-a squeak-a.
Perfect stuff for anywhere there is rubber (so under the rubber boot of the slider, yep) - though you'd probably be just fine using a slightly more all purpose grease like this: http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_172551_langId_-1_categoryId_165705 (yep, Halfords is cheaper than fleabay!)
I'll let someone who has serviced more Omega brakes than me comment on which is really best - on other cars I have, ahem, just used LM grease on the sliders  :-[ :-[ Whether I've been lucky in the boots not swelling up, I don't know.
Don't use it on the pad back or caliper edges though, pick up some copperslip: http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_203941_langId_-1_categoryId_165705
A little tiny 20g tube like that lasted me years, you don't need much ;)
SMD
  • London
    • :( nowt
« Reply #18 on: 03 May 2012, 19:33:10 »
Thanks. I will buy a tube of copper grease and a small tub of castrol grease.
