Author Topic: laptop help!  (Read 2059 times)
paul.77
  • manchester
    • 2001 2.6 estate
laptop help!
« on: 04 April 2008, 14:34:13 »
My work laptop has just died. >:( I think it's the motherboard as it just will not switch on.
my question is,
If i get a new laptop can I swap over the hard drive and will my info be saved?
thanks in advance
paul
Re: laptop help!
« Reply #1 on: 04 April 2008, 14:38:43 »
my question is,
thanks in advance
paul
Not exactly.  Assuming the HDD is still OK, put it in a caddy, and then plug in to a USB port and copy data back to new one. Afterwards, you have an external HDD to use for backups then ;)
Caddies about £10 from http://www.svp.co.uk, but you need to know if yours is a PATA/IDE (older) or SATA (newer) laptop HDD.
Re: laptop help!
« Reply #2 on: 04 April 2008, 14:42:25 »
Specifically here:
http://svp.co.uk/category/drive_cases_and_caddies
Find a suitable 2.5" one to match your existing laptop drive, ie, PATA or SATA
paul.77
  • manchester
    • 2001 2.6 estate
Re: laptop help!
« Reply #3 on: 04 April 2008, 15:05:51 »
thanks for the quick responce.
how do i find outb if it's pata or sata?
supermop
  • Hoddesdon
  • User account problem.
Re: laptop help!
« Reply #4 on: 04 April 2008, 15:08:45 »
The disk itself will tell you if it's PATA or SATA if you remove it and look at the sticker. If it's newish, I'm guessing its SATA.
If you get a new laptop of the exact same specification however, you will be able to swap out the drive and boot straight into your old build as it was before dying. I do this at work quite a lot with our Dell machines.
« Last Edit: 04 April 2008, 15:09:30 by supermop »
Re: laptop help!
« Reply #5 on: 04 April 2008, 15:11:19 »
Yup. But I'm guessing its more than a year old (hence not being done under warranty) and not a business machine (as it would have a 3yr warranty normally), so chances of getting identical model is slim  :-/
Taxi_Driver
Re: laptop help!
« Reply #6 on: 04 April 2008, 15:24:22 »
You could have a look on fleabay.........recently i bought a Dell l400 without HD or PSU.....but i already had these from my dead l400.
Cost me £35  :y Plugged in HD and PSU (swapped memory over as it only had 128M, my dead l400 had 256M) Updated bios from V01 to V08
And up and running in mins  :y
paul.77
  • manchester
    • 2001 2.6 estate
Re: laptop help!
« Reply #7 on: 04 April 2008, 15:45:05 »
it's 18months old, cant find sata or pata anywhere on the hdd.
is there another way to tell?
td great idea but nothing on ebay at the moment.thanks
dippydave
  • Sutton Coldfield, West Mids
  • how personal?
    • Vectra 2.0DTi Elite
Re: laptop help!
« Reply #8 on: 04 April 2008, 16:52:01 »
the connections are very differnet on IDE and Sata - maybe you could post a pic of your slot?! :O
on a different laptop tangent, anyone got experience with portable 2.5 drives like WD, or Seagate? (i won't touch Freecom, whatever they use inside!) or is it better to get a caddy as linked to before and put an Hitachi, TOshiba or other drive in?!!
mm what's your favourite drive - an i don't mean A roads!!:D
Vectra Elite Estate doing good post-Omega service but still not as nice to sit in.
One last Omega on the drive, one Corsa on the lawn...maybe they'll go to a good home before too long!
Martin_1962
Re: laptop help!
« Reply #9 on: 04 April 2008, 16:54:44 »
Fujitsu MH range seems good
Use the old PVR 20GB as a portable drive the Twin now has 100GB drive
dippydave
  • how personal?
Re: laptop help!
« Reply #10 on: 04 April 2008, 17:06:26 »
i'll check out fujitsu, ta!
although i need a tad more than 20GB. looking at at least 250 for my new 2.5", and gonna need a 3.5 1TB for my main portable drive!
then we're looking at a few terabytes for home storage.. but that's a long story!
Martin_1962
Re: laptop help!
« Reply #11 on: 04 April 2008, 18:16:36 »
Fujitsu are not cheap but they spin up fast and are reliable - hence Pace using them
paul.77
  • manchester
    • 2001 2.6 estate
Re: laptop help!
« Reply #12 on: 04 April 2008, 18:58:28 »
I'll put up a pic tomorrow.
I tried the hdd in another laptop and all the info is still there.
thanks for all the help so far chaps.
Taxi_Driver
Re: laptop help!
« Reply #13 on: 04 April 2008, 21:43:02 »
Do you have a 3rd PC? Just wondering possiblity of networking em so you could copy important stuff over........or even copying the files to your ISP (unless its a lot or files are big)
korum
  • Derby
    • 2003 3.2 Irmscher MV6
Re: laptop help!
« Reply #14 on: 05 April 2008, 10:13:52 »
An IDE HDD will have about 40 pins for the connection while the SATA HDD will have 2 blade like connections.
If your buy a brand new laptop it will have a SATA HDD, so if yours is IDE then you can just get a caddy and then you have a portable back up drive.
HTH
pete
