Author Topic: Vauxhall Detachable Tow Bar Bracket  (Read 2108 times)
paul8594
  • Northamptonshire
    • 53 Reg 3.2 Elite Estate
« on: 02 May 2012, 18:54:07 »
Hi, i have a 51 plate omega estate and bought a dealer direct detachable tow bar second hand from that certain auction place!
Finally got around to fitting it after lots of wire brushing, cleaning and repainting and noticed that after i tightened all the new bolts (stainless steel) the tow bar was bending the bottom of the bumper.
Have i got the brackets that go under the car between the tow bar and beams the wrong way around?
I put the brackets u side up so that they wrap around the beam and the plate / brackets fits back to back to the bumper.
Should they be turned the other way round so they are n side up so the bracket and beams are back to back as this would give me a little more depth and would possible miss the bumper.
Or do i just cut the bumper around the towbar?
Any help or comments would be appreciated
Paul
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
Re: Vauxhall Detachable Tow Bar Bracket
« Reply #1 on: 02 May 2012, 19:27:30 »
My bumper is bent as well with the tow bar. Just bolted it all in place with the bumper bent underneath, didn't fancy cutting it and making a mess of it..
« Reply #2 on: 02 May 2012, 19:29:14 »
I'd be surprised if your bumper didn't require some sort of cut, my MFL saloon had a preformed  cut at the lower edge that just required 1/8" cut either side of a flap that I've just folded up out of the way.
Stainless fasteners are NOT a good idea, they're too soft. You need high tensile bolts.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 02 May 2012, 19:30:31 »
I know on the pre facelift, they is a couple of score lines in the underside of the bumper which you cut and then bend it up and back.
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #4 on: 02 May 2012, 19:31:41 »
x1
jonathanh
  • coventry
« Reply #5 on: 02 May 2012, 20:52:33 »
typically they need a bumper cut to fit
make sure you also remove any mastic in the boot between the mounting plate and the floor - if not the bar will come loose
paul8594
  • Northamptonshire
« Reply #6 on: 03 May 2012, 18:09:39 »
Thanks for all your replies, i think i will leave it as is, me and cutting straight lines do not mix!!!
As for the stainless steel bolts, i thought i was being clever as the ones that were fitted needed to be cut off with an angle grinder!
« Reply #7 on: 03 May 2012, 19:00:12 »
If it's like my saloon, you're only cutting aboout 1/8" on either side of the flap, then there's a 'scored' line that you fold along.  :-\
