Author Topic: Diff removal  (Read 3350 times)
Diff removal
« on: 02 May 2012, 19:53:06 »
Anyone know where the 3rd bolt is that holds the diff, d/shafts out, prop all unbolted, two bolts either side at top rear of diff, will lower but won`t come out :-\
« Last Edit: 02 May 2012, 20:04:58 by RobG »
Re: Diff removal
« Reply #1 on: 02 May 2012, 20:10:38 »
Mr Haynes .....
Removal
1 Chock the front wheels securely. Jack up
the rear of the vehicle, support it on axle
stands and remove both rear wheels.
2 Remove both driveshafts with reference to
Section 8.
3 Unhook the exhaust system mounting
rubbers and lower the rear of the system
approximately 300 mm (12.0 in). Support or
tie the system in this position
4 Unbolt the propeller shaft rear flange from
the flexible drive joint and lever the propeller
shaft from the joint. Support the propeller
shaft on an axle stand - do not let it hang by
the universal joint.
5 Position a trolley jack underneath the final
drive unit, and raise it until it just comes into
contact with the underside of the casing.
6 Unplug the wiring from both ABS wheel
sensors at the connectors.
7 Unscrew the bolt securing the damping
bracket at the front of the final drive casing to
the suspension crossmember.
8 Unscrew and withdraw the bolt securing
the rear of the final drive casing to the
9 Lower the trolley jack and remove the final
drive from the underside of the vehicle.
seems to only list 2 bolts ?
« Last Edit: 02 May 2012, 20:12:45 by Entwood »
Re: Diff removal
« Reply #2 on: 02 May 2012, 20:32:45 »
Mr Haynes .....
Removal
Section 8.
#8 is 2 bolts, one either side. The one I can`t bloody find/see is highlighted ::)
Re: Diff removal
« Reply #3 on: 02 May 2012, 20:55:16 »
Is it not drivers side at the top. Torque arm bracket thing? Techy term. ;D
Re: Diff removal
« Reply #4 on: 02 May 2012, 20:56:46 »
Is that behind the bracket held with 3 torx bolts Chris :-\
Re: Diff removal
« Reply #5 on: 02 May 2012, 20:59:46 »
Pic here I think. (On a mobile)
http://www.omegaowners.com/forum/index.php?topic=90617.0
Behind the sensor
Re: Diff removal
« Reply #6 on: 02 May 2012, 21:02:13 »
Behind the sensor
Sensor is removed, didn`t see anything ;D Will have to have a shufty in the morning :y
GmasterT
  • Cambridge
  • does that drifting thing...
Re: Diff removal
« Reply #7 on: 02 May 2012, 22:27:20 »
Above the prop/output? Or just undo the 3 on the side of the diff. Then the 2 either side t the back :)
Re: Diff removal
« Reply #8 on: 02 May 2012, 22:30:28 »
I shall endeavour to succeed in the morning ;D ;D
GmasterT
  • Cambridge
Re: Diff removal
« Reply #9 on: 02 May 2012, 23:23:39 »
Cool, just FYI, the 3 bolts on the side changed size from around 99iirc, annoying when you're pissing about with digs the night before events and Vauxhall don't do them! Gimme a shout if you get stuck. The 3 on the side are a bit easier to access than the one on the top too :)
Re: Diff removal
« Reply #10 on: 02 May 2012, 23:24:35 »
Re: Diff removal
« Reply #11 on: 03 May 2012, 12:14:03 »
Thanks for all advice...................all out 8) :y :y
Re: Diff removal
« Reply #12 on: 03 May 2012, 12:17:54 »
Can you do it put it back in, then take it out again .. and take some photo's while you do it ???  :D :D :D
Methinks I might need all the help I can get ......  :-[ :-[ :-[
Appreciate what you are doing  :y :y :y :y
Re: Diff removal
« Reply #13 on: 03 May 2012, 12:31:56 »
Don`t think so Nige ;D ;D ;D Easy enough to do after you`ve done it :D. With the front damper it`s easier to undo the 3 torx bolts holding damper bracket to O/S of diff then lower leaving upper bush & bracket in situ :y
