Author Topic: Dash intermittant fault!!  (Read 4615 times)
nilocp
  • Halifax, West Yorkshire
« on: 02 May 2012, 21:17:07 »
My car is facelift 2.5V6 petrol. Speedo stops working and the ABS and tractuion control warning lights come on.
Everything else (seems) to work OK.
Any idea where to look?
Colin
Re: Dash intermittant fault!!
« Reply #1 on: 02 May 2012, 21:18:04 »
ABS ECU is dead. Can be refurbed or replaced.
« Reply #2 on: 02 May 2012, 21:26:23 »
Can't argue with that :y
Post 1998 Omega ABS units are prone to failure. "Bit fiddly to change"
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #3 on: 02 May 2012, 21:29:29 »
Check the Maintenance section, colin.....good info on there :y
Renewed mine recently....very awkward first time.....but if it happens again, I'll do it in half the time :y
« Reply #4 on: 02 May 2012, 21:35:58 »
......but if it happens again, ....
Mr Optimism ......  ;D ;D ;D
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #5 on: 02 May 2012, 21:38:34 »
Try this link, Colin
http://www.omegaowners.com/forum/index.php?topic=90627.0
Thats me Andy....ever the optimist ;D ;D ;D ;D ;D
(I got my replacement from Daz....so it will last forever) ;D ;D ;D ;D ;D ;D ;D  (famous last words) ;D
nilocp
« Reply #6 on: 02 May 2012, 22:16:13 »
Thanks for that.
And by the way, the fault has gone again!!! It has happened a couple of times in the last week, but seems to clear itself. So maybe a duff connection?
CP
« Reply #7 on: 02 May 2012, 22:27:30 »
Thanks for that.
CP
unlikely TBH, ECU is most likely :(
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #8 on: 02 May 2012, 22:49:48 »
Unfortunately, mate, TB is right....my lights came on whilst on route to WM safari park up the M40. Went off all the way home, then started again intermittently until after a few weeks they stayed on all the time ( I couldn't spell permanently)  ;D
You can get a replacement from a different engine sized car ie: 3.00ltr for 2.5ltr as long as the part numbers match. It then needs to be programmed via a Tech 2 to your engine size. Mine came from a 3.0ltr, and TB re-programmed it to 2.5ltr. Works perfect :y
Edit....should mention if you do go the second hand route, you don't know how long it will last, but its the short term cheapest. I must admit, I still have not sent my old one away to be refurbished which is the best bet, as you do then have a bit of time to save up the dosh after fitting a cheapy.
« Last Edit: 02 May 2012, 22:59:33 by terbert »
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #9 on: 02 May 2012, 23:10:18 »
Sorry to jump in but who do we trust to refurb these? Just for future reference like. Also isn't it strange how they upgraded the ABS to be engine specific yet on the Carltons the same unit is used from the tiddler 1800 all the way up to and including the Lotus Carlton. Thinking about it it must be the traction control which needs calibrating maybe.
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #10 on: 02 May 2012, 23:12:58 »
Hi doz....I think most people use a company called BBA Reman...I think they are in Rochester...
There is another place in Poole, Dorset does them also....
http://www.bba-reman.com/uk/index.aspx
http://autotekelectronics.com/autotek/?
« Last Edit: 02 May 2012, 23:18:28 by terbert »
nilocp
« Reply #11 on: 12 May 2012, 23:17:12 »
Just an update. Not got around to looking at it yet, as it has been fine all week. But today lights on again. :-\ :-\
Could this fault cause the power steering to tighten up. Or is that yet another problem. It only does it when the warning lights come on. :'( :'( :'(
« Reply #12 on: 12 May 2012, 23:24:56 »
ABS ECU affects the following systems....
Speedo  - Intermittent or totaly not working
ABS Brakes - With the light on the ABS is inoperative
Traction Control - with light on TC is inoperative
Warning Lights - ABS light on to indicate failure, Traction control light on to indicate failure
Power Steering - Servotronic has no speed input and therefore defaults to "lowest assist"
HTH  :)
Page created in 3.372 seconds with 20 queries.
