Author Topic: jacking points  (Read 10538 times)
Re: jacking points
« Reply #15 on: 05 May 2012, 10:34:21 »
front jack point:
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: jacking points
« Reply #16 on: 05 May 2012, 11:02:21 »
The first pic is a bit unclear would a sketch be better if I knew were it went I would do one
You'll easily see it when you look under the car  :y
RIP Paul Lovejoy
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: jacking points
« Reply #17 on: 06 May 2012, 10:07:49 »
nice clear pic can you do the same on rear
Re: jacking points
« Reply #18 on: 06 May 2012, 10:30:32 »
Jacking the rear of the car depends on what you plan to do.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: jacking points
« Reply #19 on: 06 May 2012, 11:52:28 »
atf change..so want car well up and level
and then to do h/b cable adjust
Re: jacking points
« Reply #20 on: 06 May 2012, 23:33:22 »
Rear on stands is a bit of a fiddle. Jack point is the centre bolt in the triangular plate for donut bush under rear door.
BUT.... the best place for the stand is the reinforced area by the exhaust hangers( bear in mind the 4pot has an exhaust box missing) the problem there is some jack and stand combinations mean, the jack will be in the way of the stand using those two areas. So some jiggling may be required with the jack position to get the stand in the right place.
 Stand on sub frame arm is a bit dodgy as it can slide off as the saddle doesn't really fit. Sub frames aren't really suitable anyway though.
Webby the Bear
  • Northampton
Re: jacking points
« Reply #21 on: 06 May 2012, 23:38:30 »
Definitely Chris. i find the best angle for the jack is straight looking at the car's doors.... just about enough room to get the stand in.... not much though
RIP Paul Lovejoy
Re: jacking points
« Reply #22 on: 06 May 2012, 23:51:20 »
Bigger the jack, more awkward it is IME.
Tbh, for ATF change, I bung the parts and £50 to my local auto box mech and he does it on a lift. Very messy job.
Steve B
  • Leicestershire
Re: jacking points
« Reply #23 on: 07 May 2012, 11:47:05 »
gave up on idea of doing atf myself gonna get a well known mechanic on here to do it for me
Steve B
  • Leicestershire
« Last Edit: 13 May 2012, 22:40:20 by bigtimecube »
amba
  • Medway towns
    • German V6
Re: jacking points
« Reply #25 on: 14 May 2012, 08:49:50 »
Axle stands look pretty fair and up to the job.
Imho that jack is pretty crap and if you really want to be able to lift a car like an Omega to a decent working height,safely,I would opt for a 3 tonne with a longer chassis .
That in the link is almost certainly a 2 tonne and would not be up to lifting the car heigh enough to get those stands under it.
pauls
  • By the sea minehead
    • Bmw x3
Re: jacking points
« Reply #26 on: 26 May 2012, 14:16:49 »
Has anybody got a good clear picture of where to put the axle stand when you have jacked up the back end up on a estate.I have looked at a few pics on hear but cannot really.
Steve B
  • Leicestershire
Re: jacking points
« Reply #27 on: 28 May 2012, 11:40:35 »
how about this jack..or is it a cheapo junk
http://www.ebay.co.uk/itm/Clarke-3-Ton-Quick-Lift-Long-Reach-Trolley-Jack-Car-Van-Ideal-4x4-High-Entry-/221034199549?pt=UK_Lifting_Moving_Equipment&hash=item3376aa39fd
amba
  • Medway towns
    • German V6
Re: jacking points
« Reply #28 on: 28 May 2012, 12:50:16 »
I personally use a 3 ton Sealey Yankie Jack as I find the saddle plate is a lot larger and gives you more flexibility when positioning it,also being a larger saddle the load is spread better.
The one in the link is probably fine at that price but if you intend using it quite regularly I would invest a bit more and get something more substantial in build quality.Just mho though  ;D
