Author Topic: central locking  (Read 3846 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
central locking
« on: 04 May 2012, 21:57:59 »
The central locking started playing up by not opening the drivers door ,this was overcome by using key but now after a couple of weeks its started working properly opening all doors.Is this the motor in the drivers door or something more central ? Cant believe its going to keep working :any advice please
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Re: central locking
« Reply #1 on: 04 May 2012, 22:51:51 »
Possibly lack of lubrication around all the levers & rods of the door lock mechanism, using the key has helped free it up. Try removing the door car & liberally spray all moving bit with chain lub.  :y :y
Re: central locking
« Reply #2 on: 05 May 2012, 11:03:16 »
Try the lube, as Andy B says, but in my experience, the next bit of cold weather, it will happen again. Solution is to change the motor.
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Re: central locking
« Reply #3 on: 05 May 2012, 11:39:50 »
Slightly off topic...appologies..
But refering to lube...what was that stuff you sprayed on my rear window, Jamie....its worked perfect since :y
If you remember, it kept bouncing back down when it got three quarters of the way up.
Re: central locking
« Reply #4 on: 06 May 2012, 10:15:37 »
I'd probably use a oil based lube on the mech. Your window would have had a 'dry' lube
Toledodude1973
  • IPSWICH U.K.
Re: central locking
« Reply #5 on: 06 May 2012, 19:55:48 »
thanks all for advice when rain stops i'll spray the mechanism with oil if that fails motor looksnext step!
