Author Topic: Steering box suitability  (Read 2856 times)
kcl
  • Finland
    • Volvo V60 D4 -14
« on: 07 May 2012, 12:18:46 »
In reference to my severe difficulties with the blind spot I've thought of replacing the box. Have been quoted a GM-refurbed box for a very reasonable price and now I need to know if this will fit. Been given these part numbers / codes: 900306/90511410 and says this will fit all models from MY94 up. Will this fit, if not, why and what options do I have?
And, if anyone has any new ideas what would be causing very itermittant stiff spot in left turns... Only left, mostly when cold, have so far not noticed it when warm. And only slow speed. this time, no play in any joints.
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: Steering box suitability
« Reply #1 on: 07 May 2012, 14:12:39 »
Have you checked the column UJ's for stiffness, its a classic symptom of stiff UJ's.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 07 May 2012, 18:16:06 »
Are there UJ's in Omega steering column? I know its classic for uj's but where are they in omega? Not too obvious to see and locate... Or am I blind? Might be that also...
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #3 on: 09 May 2012, 09:34:40 »
Answer to the original question: no. This above box is only for cars 1994-1996.
2woody
  • Northumberland
« Reply #4 on: 09 May 2012, 12:20:14 »
it sounds very much like you have a damaged recirculating ball inside the steering box.
there are two types of Omega B steering box - with servotronic and without servotronic. Both are externally identical apart from the servotronic valve.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #5 on: 09 May 2012, 13:06:35 »
Hmmm... That does make sense  :y When was servotronic introduced, how can I tell I get the correct one from scrap yard?
« Reply #6 on: 09 May 2012, 16:49:14 »
If it's got an electrical connection, it's Servotronic. :y
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #7 on: 10 May 2012, 06:38:27 »
Found a suitable donor, my previous car which was written off due an accident 1½ years back and the guy that was going to repair it has decided to make it a "organ donor". Any hints on changing the steering box or just straight forward screws off and new one in?
2woody
  • Northumberland
« Reply #8 on: 10 May 2012, 11:01:02 »
I'm sorry, we can't really say - your steering box is opposite side.
make sure that the steering idler arm is the same length as the steering box arm
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #9 on: 10 May 2012, 13:06:53 »
Ah, yes, of course, stupid me  :D Well, I will try to tackle it, I guess it will be quite a job. And I think it would be good to change the possibly lightly leaking exhaust manifold gasket at the same time.
Do the lenghts vary? Why/how? These two cars are identical so should be a straight swap, both with normal suspension, same engine and one year difference in age.
« Last Edit: 10 May 2012, 13:09:41 by kcl »
« Reply #10 on: 10 May 2012, 13:27:19 »
IIRC there are two lengths of idler & arm - but I've never seen anyone post up when the change happened or what models.. just that it's something to be aware of :y
