Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14   Go Down
Author Topic: Shocking find on Ralf....  (Read 51457 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Shocking find on Ralf....
« Reply #120 on: 10 May 2012, 22:40:52 »
im sure it will be fine.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #121 on: 10 May 2012, 22:45:27 »
I think you should get away with that as it's the exhaust cam that's advanced :-\ :-\
Cheers Lazy,
that seems to be the consensus.....ill tell you sunday  ;D
BOOM
sorry web, lmfao.  :D
hahahahaha!!!! believe me ive thought about it.
and its a very good point.... if this thing does throw a rod (i believe thats the term for when a valve shoots out the engine :o) is it likely the carnage will be contained in the engine...... dont facy turning up to A&E with no head..... or even worse a bad case of erection loss  :y
Thats "dropping a valve" which is serious,"throwing a rod" is when a con rod decides not to be attached to a piston anymore and decides to to take a look outside the block leaving a rather great hole in the side of the engine(this is very serious) ;D ;D
other rides
« Reply #122 on: 10 May 2012, 22:45:44 »
"Throwing a rod" is when a con rod (the bit between the piston and crank) makes a bid for freedom from the confines of the piston & crank, usually through the side of the engine. Tends to be fatal for the engine on account of the gaping hole and shrapnel ;)
Bending a valve won't eject bits of engine from the engine.. just.. bend things internally.
Damn, beaten to it ;)
henryd
  • west cornwall
« Reply #123 on: 10 May 2012, 22:47:01 »
I'm surprised as I'm shite at typing ;D
other rides
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #124 on: 10 May 2012, 22:47:50 »
im sure it will be fine. :y
watch this space
 ;D ;D ;D
RIP Paul Lovejoy
The Red Baron
« Reply #125 on: 10 May 2012, 22:48:46 »
happened to me with a 3.0l ford, certainly killed the engine.  :D
Webby the Bear
  • Northampton
« Reply #126 on: 10 May 2012, 22:52:55 »
connecting rod, right?
ok that makes more sense  :y
why would that happen  :-\
RIP Paul Lovejoy
« Reply #127 on: 10 May 2012, 22:57:49 »
;D Well I am half watching a film.. Ooh Sophia Myles. Mmm.
Webby - con rods break due to stresses, constant stretching & shrinking back (every time the piston hits the top of it's stroke, there's a pulling strain of many tons IIRC). Usually tuned engines beyond the design envelope of the rod will bend or break a rod either from sheer power or from detonation, that is where the fuel vapour ignites early and the flame front hits the piston crown as the piston is rising in it's bore, instead of as it's falling. You get an enormous strain on the rods and eventually, pop!
Webby the Bear
  • Northampton
« Reply #128 on: 10 May 2012, 23:01:41 »
makes sense that all necesary components are upgraded..... my mate has an orange scooby. spent £15k doing it up apparently (all engine work). he had to take it back as all the engine mods caused stress on some part (cant remember what) that was original.
RIP Paul Lovejoy
The Red Baron
« Reply #129 on: 10 May 2012, 23:15:07 »
mine exploded due to big end shell failure. at 80mph it did make a mess oh & a bloody racket. lol
henryd
  • west cornwall
« Reply #130 on: 11 May 2012, 00:51:08 »
Never ends well :-X,did something similar with a Morris 1100 many years ago,took out the gearbox as well when it went :'(
other rides
« Reply #131 on: 11 May 2012, 07:53:52 »
Cheers Lazy,
BOOM
;D
Itl be fine , for all of us learning mechanics we wait for your next update .. your learning a lot by what your doing and a bonus is so are we with your updates
Webby the Bear
  • Northampton
« Reply #132 on: 11 May 2012, 12:06:39 »
Cheers Steve! ;)
Right, thought i'd be able to afford a torque wrench (the expensive one from hellfrauds) but i can't.
i refuse to be stopped this saturday..... if i do everything up without torquing will that be ok just to start it and see if it's ok?
bearing in mind i then plan to strip it all back down for the HG job :)
RIP Paul Lovejoy
« Reply #133 on: 11 May 2012, 12:13:50 »
As long as you're sensible (I.e. don't leave anything finger tight and don't monkey off the bolts and snap them off) you'll be fine, IMHO ;)
Webby the Bear
  • Northampton
« Reply #134 on: 11 May 2012, 12:16:38 »
Exactly what i was thinking. Cheers aaron  :y :y :y :y
RIP Paul Lovejoy
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14   Go Up
