Pages: 1 ... 5 6 7 8 9 10 11 [12] 13 14   Go Down
Author Topic: Shocking find on Ralf....  (Read 51602 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Shocking find on Ralf....
« Reply #165 on: 14 May 2012, 15:13:17 »
ps, thanks for all your help james. very much appreciated!!! ;)
RIP Paul Lovejoy
« Reply #166 on: 14 May 2012, 15:21:57 »
Very well done mate :y
Just to confirm -
with crank locked at TDC, and with the gauge held between the pulleys, the marks are dead in the centre - and the tensioner set right? All torqued up, re-rotated, and re-checked?If so, happy days :y :y
Oh yes ;)
Only thing i didnt do was torque them as i dont have a torque wrench with the low numbers. however, i did them up tight but not so much id strip them ;)
Does your T wrench not do 40nm even?
On a play-around / learning car like Ralf, doing them to a sensible torque by hand will be fine. Make sure you get a torquewrench if you do the job for real, though :y
Webby the Bear
  • Northampton
« Reply #167 on: 14 May 2012, 15:26:02 »
Just to confirm -
Oh yes ;)
oh defo will mate, thanks  :y :y :y
yeah my ''big bertha'' torque wrench goes down to 40nm.... however the bugger has a bigger drive than the one on the E12 socket  ::) ;D
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #168 on: 14 May 2012, 15:26:50 »
.....and i dont have the correct adapter  ::) ;D
RIP Paul Lovejoy
martin42
« Reply #169 on: 14 May 2012, 15:27:59 »
what size adaptor do you need?
Webby the Bear
  • Northampton
« Reply #170 on: 14 May 2012, 15:29:58 »
hi martin,
not sure mate. but to be honest it doesnt really matter anyway cos i haven't got a torque wrench that will do 25nm  ::)
next on my list to buy though. going to get a good 'un..... the smaller version of my big bertha  ;D
RIP Paul Lovejoy
SMD
  • London
    • :( nowt
« Reply #171 on: 14 May 2012, 16:14:50 »
Well done Steve!  :)  Are you sure you can wait till the weekend to fire her up? Don't you want to know if it runs better NOW?!
Webby the Bear
  • Northampton
« Reply #172 on: 14 May 2012, 16:23:42 »
Haha to be honest mate i'm a bit exhausted from it. the fact it was my first time  :-[ :D and the fact i made a few mistakes and the final fact that the belt had no markings i made a right meal of it  ;D ;D ;D
but yeah i defo want to fire the old boy up..... not lookin forward to reassembly.  :o
RIP Paul Lovejoy
« Reply #173 on: 14 May 2012, 16:58:27 »
It's a 2.5, so not even a plenum to refit.... 30 minutes work... put it together man ;D
Kidding - taking your time whilst learning is a great thing to do :y :y
Webby the Bear
  • Northampton
« Reply #174 on: 14 May 2012, 17:23:09 »
Haha yes. 30 min job will take me at least a day  ;D
can i ask a quick Q........
for the most part when i was readjusting the cam positions i had the crank at 60o before TDC.
However, when i took off the belt again i noticed that they had slipped out of sync as there seems to be quite a bit of play in the cam locks.
anyway i went to readjust them but forgot to put the crank back and it was sat at TDC. The cams then took a bit of getting right cos they were just spinning right and left when i tried to get them spot on... eventually got them in place.
anyway my question is will i have done any damage when i accidentally moved the cams whilst the crank was at TDC?
i dont think so bearing in mind the engine was running with cam 1 at 4 or 5 teeth out and still worked... just. but would love your thoughts. Also i didnt force anything.
Cheers all
RIP Paul Lovejoy
« Reply #175 on: 14 May 2012, 18:04:58 »
Worth getting adapters, about a fiver from hellfrauds. Keep the receipt, you *will* break them
Webby the Bear
  • Northampton
« Reply #176 on: 14 May 2012, 19:56:37 »
PICS :)
Here's Ralf all timed up correctly..... water pump and all other things to follow when my phone decides it wants to send e mails again  ::)
Tensioner bang on the line as it's a re-used belt:
Finally, just looking around at bits and bobs.... does this thin tube go in that small pipe.....??
RIP Paul Lovejoy
« Reply #177 on: 14 May 2012, 20:27:54 »
Is it just me / the picture / the angle - or does cam one look a little too advanced, given the crank is at TDC?
« Reply #178 on: 14 May 2012, 20:31:00 »
Ps - that last photo looks v small, but the thing you've circled at the front is where the vaccum goes for your SAI :y
PPS - wtf's going on with the HT leads from the 1-3-5 bank, running under the EGR and over the top of the plenum like that? Don't recall it being like that when I took Ralfs plenum off and fixed the coolant bridge leak, prior to your ownership..  :-\
Webby the Bear
  • Northampton
« Reply #179 on: 14 May 2012, 21:01:18 »
loll no its just the angle of the photo ;) i assure you theyre spot om the markson the tool ;)
as for the leads the disspc is out so all  leads are out too... ill put it all back together soon ;)
RIP Paul Lovejoy
Pages: 1 ... 5 6 7 8 9 10 11 [12] 13 14   Go Up
