Author Topic: Wishbone replacement  (Read 6051 times)
JimE
Re: Wishbone replacement
« Reply #15 on: 09 May 2012, 18:40:11 »
god what a cynical site.   ::) I do have faith in them, have used them for years and will continue to do so..... So there! ;)
« Last Edit: 09 May 2012, 18:46:33 by JimE »
« Reply #16 on: 09 May 2012, 20:02:57 »
Pray tell..? Full geometric set up and new wishbones fitted for £75. I'll drive down meself next time.  :)
« Reply #17 on: 09 May 2012, 20:08:11 »
At that price, he must already have the wishbones.
Crazycarzowner
« Reply #18 on: 09 May 2012, 20:10:34 »
£75?
The full geometric costs more than that!
  • Auckland
    • Mazda MPV
« Reply #19 on: 09 May 2012, 20:14:24 »
Cynical yes, but not without good reason unfortunately :(
It seems that the data issued by Vauxhall is far too lax. Places that offer 'full geometry check' tend to take readings, see that they are within the published limits and leave it at that.
What is the name of the garage you are taking your car too? (if you don't mind me asking?)
JimE
« Reply #20 on: 09 May 2012, 20:39:36 »
Yep already got the wishbones from father-in-law, late birthday present. He too uses the same garage for his v6 Omega
« Reply #21 on: 09 May 2012, 20:44:14 »
What make?
The wishbones on the Omega never really fail, its the rubber bush. You are replacing current ones because they are warn? MOT adviso/fail?
Often, best case is to actually re-use the old wishbone, and just fit a new bush.
But of course, your motor engineers would have told you that?  ;)
Jimmy680
  • Lincolnshire
    • Omega 2.6 V6
« Reply #22 on: 09 May 2012, 22:13:25 »
Where the strut bolts to the hub, is there not a slot where the strut locate into so it goes back in the same position as it originally was?
« Last Edit: 09 May 2012, 22:15:26 by Jimmy680 »
  • Auckland
    • Mazda MPV
« Reply #23 on: 09 May 2012, 22:38:40 »
The strut bolts to the hub using two bolts. One of the holes is slotted to allow movement/adjustment.
There isn't any means of positive location, any alignment is lost as soon as the bolts are slackened.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #24 on: 09 May 2012, 23:57:55 »
In these parts, there's only one person that I trust to do this task correctly ..............
........... and that's me! 8)
However, good luck to the OP! ;)
JimE
« Reply #25 on: 10 May 2012, 14:54:42 »
What make?
[/quote]
I was told when I bought the car the bushes were shot, the guy knocked the price of a new pair of wishbones off the price so I wasn't going to say no just buy the bushes  ::) It is easier to fit a complete unit rather than try and get the old bushes out and new ones in. If I had to pay for it myself it would have been a case of new bushes!
So therefore there was no need for my garage to mention it!
