Author Topic: Self Levelling Shocks  (Read 3464 times)
« on: 08 May 2012, 13:09:53 »
Are they the same between Saloon & Estate?  :-\
Re: Self Levelling Shocks
« Reply #1 on: 08 May 2012, 13:34:55 »
I wouldn't think so. I'd expect the estate's to be shorter
« Reply #2 on: 08 May 2012, 13:38:55 »
I see RobG has some for sale, but not sure differences  :-\ - I know springs are taller, but not sure if shocks would just automatically adjust to saloon/estate  :-\
Just took motherT's estate to do a run, something is seriously wrong with back suspension. Come off a bump & the nearside rear keeps on bouncing half a mile down the road  :o  ;D
If one shock looses pressure, does that result in SL system shutting down? (not hearing the pump make any noise)
Looks like the shocks are feked (never changed in our ownership) they are leaking fluid & they look far too low for me.
Jacked up the rear to take a look:
Offside not jacked up, but looks a little low? (not got much experience with SL stuff)
Letting the nearside down again...
Either way these shocks look like they have better days!
« Reply #3 on: 08 May 2012, 13:39:11 »
Nope
« Reply #4 on: 08 May 2012, 13:40:43 »
Nope
Nuts. Guessing ones you have are Saloon?
Edit, yup.  :(
« Reply #5 on: 08 May 2012, 13:42:23 »
Nope
Edit, yup.  :(
;D ;D
amba
  • Medway towns
    • German V6
« Reply #6 on: 08 May 2012, 15:40:20 »
Saloon,s are different from estates as I found out when dealer supplied me incorrect parts a few years ago.
« Reply #7 on: 08 May 2012, 18:28:23 »
Dealer only :y £100 each :'( might be best to renew top mount gubbins at same time :-\
IIRC PM Jimbob for details :y
« Reply #8 on: 08 May 2012, 18:45:48 »
around £75 on Trade Club though  :y :y
« Reply #9 on: 08 May 2012, 18:51:03 »
I'll have a pair of known good ones (about 3 years old IIRC) for an Estate up for sale soon ::)
« Reply #10 on: 08 May 2012, 19:16:12 »
How soon is soon? Need them by not this weekend but next.
Thanks Andy, was not sure on the price. Not too bad, considering this is the first time I've touch anything suspension wise on the estate since we bought it around 4 years ago now.
Bolts soaked in WD40, hopefully give it some time to soak in.
« Reply #11 on: 08 May 2012, 19:18:14 »
Top nuts should be OK, they're sheltered from the element up in the wing/boot. The bottom bolts can be tight though.  :y
« Reply #12 on: 08 May 2012, 19:22:15 »
Yeah, from past experience I've learned to wire brush the thread as well, which is exposed. Otherwise it pulls the dirt through!
« Reply #13 on: 08 May 2012, 20:18:11 »
You're learning!  :y :y :y
I recently had to swing of my breaker bar for each turn of the bolt removing one of them. T'other came out a piece of the proverbial.  ;)
« Reply #14 on: 08 May 2012, 21:04:19 »
Not going to be that soon... Not got the pennies for the replacement shocks/springs for a few weeks at least :'(
