Author Topic: HELPPPPP!!!! 2.2 DTI Fuel Tank Breather???  (Read 2242 times)
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
« on: 08 May 2012, 19:47:55 »
Right problem is ive got fuel leaking out of the plastic fuel lifter seal, i believe its a breather problem unless proven other wise as each time i put pressure down own the boot fuel pisses out through the seal ive done it up tight but its still pissing out onto which was the road now a bucket
Sam
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
Sam Burton
    • Many
Re: HELPPPPP!!!! 2.2 DTI Fuel Tank Breather???
« Reply #1 on: 08 May 2012, 21:31:10 »
any oil burner owners????....... :-\
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #2 on: 08 May 2012, 21:39:49 »
breather is just at back of tank just off centre. think you going to need a new pump tank seal or the metal part of the top of the tank ie bit you screw down, may be badly pitted with rust. :-\
Solar charger fitted.
If not Broke dont fix it..
Sam Burton
    • Many
« Reply #3 on: 08 May 2012, 21:45:36 »
Ive just ordered a new metal part of the sender unit does anyone know of a decent place to get a new seal (the Black One)??
Agemo
  • Cleethorpes
  • Insignia
« Reply #4 on: 08 May 2012, 21:54:12 »
Mine leaked once, just after I had cleaned out the swirl pot. I hadn't got the rubber seal in quite right, I think you are in with a good chance of sealing it if you have another go, I know it's not easy though.  :-\
Sam Burton
    • Many
« Reply #5 on: 08 May 2012, 22:06:04 »
Right Agemo im gunna take your word for it and use some fuel up for abit then this weekend ill do it properly take fuel lines off give it a good clean up and try again, is it worth putting any sealant on the seal (sounds weird) when re-assembling
Sam
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 09 May 2012, 08:56:30 »
No sealant required, if you get it right you won't need sealant, & if you get it wrong, the best sealant in the world won't make it Diesel-tight. You need the right rubber seal, the petrol ones are as different size if memory serves.  ::)
