Pages: [1] 2 3  All   Go Down
Author Topic: v6 disspack relocation  (Read 10225 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« on: 09 May 2012, 10:26:15 »
has anyone relocated the disspack from the rear of the head?.
where would you put it?.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: v6 disspack relocation
« Reply #1 on: 09 May 2012, 10:28:33 »
Not for good.... but to easily switch between disspacs during strip down i sat mine on the plenum  ;D
as for relocation youll find that disspac connector dont want to move very far!
RIP Paul Lovejoy
« Reply #2 on: 09 May 2012, 10:28:40 »
Cant see the point, it fits ok, is not that bad to change and will only realy need doing once in the engines life.
« Reply #3 on: 09 May 2012, 11:16:01 »
Recall someone had moved it due to access and scuttle leakage  :-\
Webby the Bear
  • Northampton
« Reply #4 on: 09 May 2012, 11:22:06 »
Where on Earth would you put it? lol I nearly lost my hand due to the limited access!  ;D
I'd say the position is a bit shite. right under the scuttle where potentially water can leak. and also difficult to quickly replace leads and such.... but i really cant think where else it would go.  :-\
RIP Paul Lovejoy
« Reply #5 on: 09 May 2012, 11:32:10 »
With a bit of bracketry im sure it could be moved , once the scuttle has been off it seems they prone to leak so re sealing with goo is a must . I was going to make a drip cover for the coil pack when i replaced mine , just a matter of what to use and how to secure it  :-\
Webby the Bear
  • Northampton
« Reply #6 on: 09 May 2012, 11:35:54 »
I was thinking the exact same thing. only thing stopping me was thinking where would it drain off to?  :-\
RIP Paul Lovejoy
« Reply #7 on: 09 May 2012, 11:39:04 »
Just runs down the back of the engine i think , with plenty of sealant on the scuttle for a start to stop most of the dripping then the cover it should be good , maybe the OP was to move for a different reason
Webby the Bear
  • Northampton
« Reply #8 on: 09 May 2012, 11:41:51 »
But wouldn't that then drip on the crank sensor or something else quite important?
I reckon seal it up and have a drip tray attached to the scuttle itself. then drain out every month ;)
RIP Paul Lovejoy
« Reply #9 on: 09 May 2012, 11:48:55 »
Don think there would be that much to cause any problem , no more than what gets sprayed underneath when its raining . I think someone said they used some of that shed felt draped over the coil pack , might have a go with that  :)
Webby the Bear
  • Northampton
« Reply #10 on: 09 May 2012, 11:54:57 »
Now that sounds like a good idea.
Steve, if you do this defo post a guide as i bet you'd get lots of people doing that  :y
RIP Paul Lovejoy
« Reply #11 on: 09 May 2012, 12:03:18 »
Just wondering about the heat issue  :-\ dont want it melting and causing more grief .
Webby the Bear
  • Northampton
« Reply #12 on: 09 May 2012, 12:09:24 »
Why not have it attached to the block ''eye'' and not touching the d/pc itself and create a ''run-off'' ;)
RIP Paul Lovejoy
« Reply #13 on: 09 May 2012, 12:14:02 »
Will have a look , just need to nick some felt out me dads shed now  ;D :y
twiglet
  • Norwich, Norfolk
« Reply #14 on: 09 May 2012, 12:17:16 »
I recently bought a facelift 3.0 Elite off another OOFer with the intention of breaking it.  This has had the dis-pack relocated next the the PAS reservoir, where it has been cable tied in place!!  :o
Pages: [1] 2 3  All   Go Up
