Pages: 1 2 [3]  All   Go Down
Author Topic: v6 disspack relocation  (Read 10234 times)
Murph
  • Dartford, Kent
    • 2.5 Estate
Re: v6 disspack relocation
« Reply #30 on: 09 May 2012, 18:04:04 »
Dunno - will look on the phone as I'm 200 miles from the car at present.
I relocated mine due to my spare being completely different and not fitting on the original bracket.
*EDIT*
Sorry no pic on my phone so I'll take one on monday.
« Last Edit: 09 May 2012, 18:06:07 by Murph »
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #31 on: 09 May 2012, 18:06:44 »
also a lot easier if leads need changing id imagine
RIP Paul Lovejoy
« Reply #32 on: 09 May 2012, 18:11:46 »
Leads only need changing due to poor servicing, failed cam cover gaskets and oil in plugs will case HT leads to break down.
A well maintained car should go for 100k+ easily on a set of HT leads + DIS pack
Webby the Bear
  • Northampton
« Reply #33 on: 09 May 2012, 18:14:38 »
oh ok, thats fair enough then. i didnt know that. may as well keep as is then  :y :y :y
RIP Paul Lovejoy
« Reply #34 on: 09 May 2012, 19:13:16 »
I relocated mine to just below the airbox - there's even a cutout in the box that looks made to measure.
I made up a small loom to extend the wiring without damaging the original wiring and knocked up a bracket out of some 1mm steel.
I did need to borrow a no.6 lead from the Carlton though, and that one has to run over the top of the engine but after 3 months I have had no problems.
you got a pic of this murph? sounds great ;)
+ 1 pic would be great  :y
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #35 on: 09 May 2012, 20:59:01 »
I'll get one on monday - somebody should remind me though, my head's like a sieve!
« Reply #36 on: 09 May 2012, 22:01:15 »
One removed, the options are re fit it, or relocate it. Easier to re fit it surely? :-\
Often wondered about sliding a plastic guard of some sort down the back of the engine to keep and water off... But then it will rattle, be fiddly to fit, be in the way for other jobs, and sealing the scuttle is easier, ESP as it has to come off to get the dis out anyway.
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #37 on: 15 May 2012, 22:51:43 »
As requested... difficult to see in a photo though...
« Reply #38 on: 16 May 2012, 14:58:11 »
That is certainly easier to get to  :y
« Reply #39 on: 16 May 2012, 15:24:05 »
Not sure I'd want my coil pack sitting under that amount of water  :-\
amba
  • Medway towns
    • German V6
« Reply #40 on: 16 May 2012, 15:49:15 »
Would also imagine the leads are going to get pretty hot running past the exhaust manifold,although a noval design.
Each to their own I suppose ;D
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #41 on: 16 May 2012, 17:21:01 »
after looking at several options ive decided to leave it where it should be, having lpg on aswell just limits the space even more so it stays as. :y
Pages: 1 2 [3]  All   Go Up
