Author Topic: Fault Codes  (Read 2312 times)
KJO
  • Cork
Fault Codes
« on: 09 May 2012, 12:38:39 »
Need help to know what these fault codes are, PO727, P1700, P0700, they were read from the engine ECM but they relate I think to the auto box. The problem I'm having is that the car starts up in limp mode on a regular basis. The only way of overcoming the limp mode is to stop & restart the engine. When it starts up in limp mode the light with a car & a spanner through it comes on, when it's not in limp mode the light does not come on. The fault light comes on when the engine does not start cleanly & turns over lazily & the auto box goes into limp mode. The cam sensor has been replaced by one from Quinton Hazell. The car is an X reg 2.2 petrol auto & has done 145k miles. There is a slight blow from the exhaust manifold I don't know if this is affecting the start up & hence causing the limp mode problems.
Re: Fault Codes
« Reply #1 on: 09 May 2012, 12:47:08 »
0700.......autobox "malfunction"
0727.......engine speed circuit No Signal
1700.......request from autobox to illuminate EML
If cam sensor was not genuine, purchased from Vauxhall/Opel, strong possibility that is your problem especially with haphazard starting
KJO
  • Cork
Re: Fault Codes
« Reply #2 on: 09 May 2012, 13:12:50 »
The cam sensor was a Siemens. You still think it could cause the problem?
Re: Fault Codes
« Reply #3 on: 09 May 2012, 13:19:40 »
Purchased from where?
KJO
  • Cork
Re: Fault Codes
« Reply #4 on: 09 May 2012, 13:28:15 »
Vauxcentre
KJO
  • Cork
Re: Fault Codes
« Reply #5 on: 09 May 2012, 13:36:11 »
Sorry wasn't the Vauxcentre now I remember it was on line from MicksGarage in Dublin. Was supplied to him by Quinton Hazell
Re: Fault Codes
« Reply #6 on: 09 May 2012, 13:59:30 »
Copy & paste of online chat with said garage.
robert:
Hi, Is 87048 Camshaft Position Sensor for Omega 2.2 a genuine OEM part or aftermarket
  Call accepted by operator Colin. Currently in room: Colin.
Colin:
Hi Robert.
Colin:
Let me look into that for you, just a moment please.
Colin:
Can you let me know your license plate / registration number and I will look it up for you?
robert:
Colin:
Colin:
This item, from a company called Meat and Doria, could well contain a Bosch sensor in it, however I cannot tell you this for certain. It would be however up to the standards and specifications as laid down by GM.
robert:
OK thanks.
So it`s not a genuine part, and if you read their FAQ you will find
Frequently Asked Questions
Please note we do not sell Genuine parts (i.e main dealer parts) and that all references to Car marques & cars are solely for identification purposes only.
Think that answers your question as to whether you have a genuine cam sensor. :)
Re: Fault Codes
« Reply #7 on: 09 May 2012, 14:00:20 »
Pattern sensors are known to be problematic, return if it you can and replace with a genuine sensor   :y
KJO
  • Cork
Re: Fault Codes
« Reply #8 on: 09 May 2012, 14:12:40 »
One lives & learns. Iv'e asked andyc to give me a price for one. Many thanks. :'(
Re: Fault Codes
« Reply #9 on: 09 May 2012, 15:44:08 »
Can't go wrong there, good choice  :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Fault Codes
« Reply #10 on: 09 May 2012, 17:55:36 »
they are £88.80 if you walk in main dealer .. think andy gives you 20% off that ie; £71.04
KJO
  • Cork
Re: Fault Codes
« Reply #11 on: 09 May 2012, 18:24:51 »
Can get them for £69 from andyc. See recommended suppliers. They cost €135 here in Ireland.
