Author Topic: omega 2.6 estate  (Read 1412 times)
jest
  • west sussex
    • omega 2.6VG ESTATE
omega 2.6 estate
« on: 09 May 2012, 19:58:12 »
hi i have an omega 2.6 v6 estate.i donot use the car everyday but when i do decide to use it the battery is flat. i dont get a warning light and i have brought a new battery but it still goes flat.help
Re: omega 2.6 estate
« Reply #1 on: 09 May 2012, 20:08:52 »
How often is it left?
Any modifications? Different stereo?
jest
  • west sussex
« Reply #2 on: 09 May 2012, 20:18:25 »
NO MODIFICATIONS ONLY A TOW BAR. CAN GO FLAT FROM FULLY CHARGED TO FLAT WITHIN A WEEK.
« Reply #3 on: 09 May 2012, 20:21:57 »
Just a friendly pointer, capitals on forum posts are considered as shouting, please don't use them  :y
Are you sure its charging correctly?
Have you put a volt meter on it? Get some reads of off/idle and with say 3k revs?
jest
  • west sussex
« Reply #4 on: 09 May 2012, 20:27:45 »
sorry didnot know it was wrong to use capitals[im new to this] yes fully charged
thanks
« Reply #5 on: 09 May 2012, 20:29:07 »
thanks
Thats not what I meant, have you run volt meter across it with engine running?
Its possible the alternator is not giving it enough power.
With engine running, I believe it should give around 14.4v ish. If its not, the alternator is tired  :y
jest
  • west sussex
« Reply #6 on: 09 May 2012, 20:32:39 »
many thanks. will give it a try in morning.
thanks again :)
