Author Topic: Indicator/dipped mainbeam switch  (Read 2176 times)
wightyboy2
  • Isle of Wight
« on: 10 May 2012, 16:10:19 »
Hi , I have a Mreg (95) Omega 2.0 16v gls estate and the indicator switch which also operates the main and dipped beam has finally broke , it was on the way out as it had become worn and the headlamps would keep coming on finally the other day I broke the arm off it , I started to read the haynes manual about how too replace it and seems to be saying that I need to remove the steering wheel and airbag etc to do this , does anyone know if that is necessary for sure ,also has anyone any idea of how much they cost and best place to get one from? any advice much appreciated , Cheers
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Indicator/dipped mainbeam switch
« Reply #1 on: 10 May 2012, 16:20:10 »
can change with out doing all that, there is just enough space to get it off but take the battery off as can trip the air bag, dont start to take of for at least 10min,  this is for 95 model http://www.ebay.co.uk/itm/VAUXHALL-OMEGA-INDICATOR-SWITCH-STALK-E-394-/160727675638?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item256c1db2f6
newer omegas have a cable fitting.
« Last Edit: 10 May 2012, 16:24:57 by freecall666 »
Solar charger fitted.
If not Broke dont fix it..
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 10 May 2012, 16:25:47 »
I think Mr Haynes say the wheel needs to come off, but it is quite easy doing it in place. Remove shroud, then disconnect the electrics at the plug, then you either squeeze tabs, or pull them outboard, & the switch assembly slides out.  :y
As said above, disconnect battery, have cuppa, then start job.
« Last Edit: 10 May 2012, 16:27:21 by Agemo »
« Reply #3 on: 10 May 2012, 19:00:15 »
No need to remove wheel.
Steering at 90 degreesm remove upper cowling screw, steering at 90 degrees other way, remove other upper cowling screw, and remove upper cowling.
Remove 3 screws holding up lower cowling, and drop slightly.
Release clips holding stalk base, withdraw, and unplug
wightyboy2
  • Isle of Wight
« Reply #4 on: 10 May 2012, 19:24:37 »
Wow thanks for the replies really grateful , freecall666 i have ordered up the switch from your link he doesnt deliver too the Isle of wight but I have sent him a personal message requesting that he does and that I would cover any extra costs for delivery thanks again for taking your time too reply , cheers :y
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #5 on: 11 May 2012, 07:26:38 »
If you have any problem I have one off a 1998 which is the same and I can drop it in the post recorded delivery for £6 and you should get it next day(according to Royal Mail).
best wishes
Simon.
wightyboy2
  • Isle of Wight
« Reply #6 on: 16 May 2012, 08:51:44 »
All done and sorted , cant thank you guys enough for your help ordered up the part from the link that freecall666 kindly provided and bingo it arrived today , 20 mins later installed and jobs a goodun , Thanks again for all your replies  :y
freecall666
« Reply #7 on: 16 May 2012, 13:40:49 »
nice one  :y
