Author Topic: Rear brake pads  (Read 6308 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Rear brake pads
« on: 10 May 2012, 17:05:11 »
Could someone check the price of rear pads for a 52 2.6 estate vented discs on Tc. hopefully the price I been given is wrong £51 +vat fronts were only£15+
Re: Rear brake pads
« Reply #1 on: 10 May 2012, 17:09:21 »
Have a feeling vented rears are quite pricey! Sounds about right  :(
LFF64
  • HADDENHAM BUCKS
Re: Rear brake pads
« Reply #2 on: 10 May 2012, 17:14:40 »
Blimey thats expensive  then  :o
Re: Rear brake pads
« Reply #3 on: 10 May 2012, 17:17:28 »
I thought all pads were the same  :-\ :-\ :-\ :-\
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Rear brake pads
« Reply #4 on: 10 May 2012, 17:21:41 »
Showing on Trade Club as £44.61.
Plus vat I assume.
Re: Rear brake pads
« Reply #5 on: 10 May 2012, 17:26:55 »
Think vented rears on 2.6/3.2 are super expensive compared to 3.0/2.5 non vented which are only around a tenner
Re: Rear brake pads
« Reply #6 on: 10 May 2012, 17:27:59 »
But why should the pad be any different? It's just a thicker disc!  ??? ???
martin42
Re: Rear brake pads
« Reply #7 on: 10 May 2012, 17:29:58 »
rear pads are the same but longer pins for vented,mine only cost me £5 last year but that was because the idiot posted them to  a different address in the street and waited 2 weeks for them  ;D
YZ250
Re: Rear brake pads
« Reply #8 on: 10 May 2012, 17:31:52 »
According to TC they are.  :-\ Well, the 2.6 and 3.2 are. Didn't look at the others as it was irrelevant.  :y
Re: Rear brake pads
« Reply #9 on: 10 May 2012, 17:31:58 »
Just dug up the old thread I was thinking of, looks like the vented ones are not listed on TC, despite them being the same:
http://www.omegaowners.com/forum/index.php?topic=85246.15
andyc
  • Norfolk
Re: Rear brake pads
« Reply #10 on: 10 May 2012, 17:35:03 »
Pad set for Vented discs are not on the TC program and trade @ £51.31 + VAT. These pads do also come with the pad pins and springs.
Pads for the Solid discs which are on the trade club program and come out at £12.47 + VAT but do not come with any fittings
What you can do though is use the Solid pads on the Vented Caliper but either re-use the fitting kit or buy new springs and pins
The vented pins are £4.51 each + VAT and the springs are £3.45 each + VAT , so to use the solid pads with a new kit your looking at £37.41 + VAT
I will say that i've only heard of the Solid pads being fitted to the Vented calipers so i can not confirm if this will work so its at your owen risk
Oh and FYI the Vented pads are on back order with GM at the moment
Cheers
Andy
Thetford. Norfolk
Re: Rear brake pads
« Reply #11 on: 10 May 2012, 17:36:46 »
Great clarification as always Andy  :y
I've always re-used the old pins  :)
YZ250
Re: Rear brake pads
« Reply #12 on: 10 May 2012, 17:42:50 »
Hi AndyC,
What are 90541931 showing on TC just for clarification please, so I don't confuse the issue.
Edit. Doh they are shoes.  :-[ :-[ They are listed under Rear Pads.
Cheers
Regards
Alan
« Last Edit: 10 May 2012, 17:46:34 by YZ250 »
Re: Rear brake pads
« Reply #13 on: 10 May 2012, 17:47:46 »
At risk of agreeing with you ................  ::) ::) ::)
So do I!
I've replaced the anti-rattle spring that fits at the top recently & just bought them separately.  :y :y
Re: Rear brake pads
« Reply #14 on: 10 May 2012, 18:21:03 »
So do I!
Something is very, very wrong!  ;D
