Author Topic: Knocking up a plate .  (Read 1978 times)
« on: 11 May 2012, 12:06:50 »
Decided to make up a plate to cover the coil pack . Aluminium sheet and a bit of hammer forming .
The sheet is formed to sit just snuggly to the bulkhead with a small gap , and fixed to the bolt of the cable tray to stop it vibrating loose .
And some black gooo under the bolt , tray slopes towards the back .
Seems the water is getting through to the foam so im going to remove that and investigate where its coming from , i already sealed the scuttle last month  >:( this plate will take any excess water away for now ... i dont want to be replacing another coil pack just yet . Not every ones cup of tea i know but im happy with it and it dont look too out of place .
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Knocking up a plate .
« Reply #1 on: 11 May 2012, 12:14:52 »
damn it. cant see the pics as at work. good job though. prettyness generally shouldnt matter ;)
RIP Paul Lovejoy
« Reply #2 on: 11 May 2012, 12:28:20 »
My only thoughts with that is airflow around the back of the block, already gets quite warm back there  :-\
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
« Reply #3 on: 11 May 2012, 12:37:04 »
Send it my way ill spray it black so it looks better if your fussed :y
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
Webby the Bear
  • Northampton
« Reply #4 on: 11 May 2012, 12:39:23 »
There you go Steve.... OOF spirit. gotta love it ;) :y :y
RIP Paul Lovejoy
« Reply #5 on: 11 May 2012, 14:24:00 »
 ;) well its only a trial for the mo , i was going to spray it later on . I didnt want to use shed felt due to any heat issues and it melting . Ill take the car for a good run and see if the plate gets too hot ...easily removed  :)
martin42
« Reply #6 on: 11 May 2012, 14:30:53 »
i have all the dressers for bending metal,and im of work,would have popped over and helped  :y
« Reply #7 on: 11 May 2012, 14:33:46 »
Dam  :(
Its not a bad effort with using tin snips and hammering the edges round a halfpipe   ;D :y
martin42
« Reply #8 on: 11 May 2012, 14:36:02 »
oh well if you decide to do a mk11 plate you know ive got the tools  ;D
« Reply #9 on: 11 May 2012, 14:38:56 »
Cheers mate , that is the mk2 i made the first one too short  ;D Could have been worse if i had got the welder out  ;D
