Author Topic: Fan inside passenger wing  (Read 2561 times)
RN55ONE
  • West Midlands
    • Omega 3.0 v6 F/L Manual
« on: 12 May 2012, 17:17:11 »
Hi,
I was in the process of removing the passenger wing to replace it with a non-rusty one.
When I took the wing off a fan fell out. It was not correctly connected to the pipe which follows the contours of the wheel arch.
Can someone tell me what this fan is used for? do I need it? And which way it is supposed to be facing when I put the wing back on?
Also is it the same scenario on the drivers side?
Cheers
Re: Fan inside passenger wing
« Reply #1 on: 12 May 2012, 17:29:35 »
Hi,
Cheers
Blows cool air to engine ECU, nothing on driver`s side except S/L pump if you have it
RN55ONE
  • West Midlands
« Reply #2 on: 12 May 2012, 17:32:11 »
Cheers Rob,
Do I need it? I have read somehere that some cars have it some don't, so does this mean I can leave it off with no ill effects?
Not sure if it even works - guess the only real way to test it is to get the car 'hot' and see if it comes on.
« Reply #3 on: 12 May 2012, 18:32:27 »
Cheers Rob,
Every Omega that I`ve broke has had one.  ;D
RN55ONE
  • West Midlands
« Reply #4 on: 12 May 2012, 18:35:34 »
Guess I'll leave it in then - thanks
2woody
  • Northumberland
« Reply #5 on: 15 May 2012, 15:25:18 »
almost certainly not needed in UK.
it's there to pull cooling air through the fusebox, which could be important in cars used in +40 degree heat with a constant solar load ( gulf states, USA, possibly Spain, Morocco, etc. )
it will also be important on UK days where the temperature goes into the 40s
RN55ONE
  • West Midlands
« Reply #6 on: 15 May 2012, 15:31:49 »
When the car got over 90 degrees and the fans kicked in I always thought to myself that the fan was quite loud.
Always seemed like the sound was coming from the passenger side foot well.
Now I know that the fan sound was the Fuse Box fan.
Cheers guys.
