Diff bolts
Started by Entwood, 13 May 2012, 14:41:42
Thanks Chris .... so if anyone has 3 pre 2001 bolts from the side plate .. I'll be pleased to hear from you .. if not its a visit to the stealers on thursday to order them .. as a pound to a pinch of **** they won't have them in stock .. :(
Quote from: Entwood on 15 May 2012, 20:10:25
Diff you have now was 2001 (Y) Nige so reckon it`s a bit hit & miss when the actual changeover was :-\
Quote from: RobG on 15 May 2012, 20:15:41
Agreed .. but mine is 2001 (51) .. so I'm "hoping" that mine is the later one and yours the earlier .. meaning I need the "older" bolts .... 50/50 call I know .... I'm expecting to go to the stealers Thursday TBH .. for the sake of £6 ish .. and I'll take the bolts from mine to ensure I get different ones !!!
sjc
Well, if no joy at stealers, I have a set of the older ones here - they're an E14 Torx head.
Quote from: sjc on 15 May 2012, 21:33:17
Thanks .. I'll keep that in mind for after Thursday's visit !!
Shackeng
Quote from: Entwood on 15 May 2012, 21:24:21
If you ask for my friend Darren, assuming its Skurrays at West Swindon, he will know exactly what you are talking about, as we had a long chat about them today. :y
SJC ... you have a PM ....
Stealers can get me the bolts, from Germany, 12 - 14 days, but only in packs of 10.
Quote from: Entwood on 17 May 2012, 18:00:49
Tried AndyC?
Quote from: tunnie on 17 May 2012, 19:36:15
Tried AndyC?
According to the stealers here, the computor shows nil stock within the UK both at other stealers and depots, hence the requirement to order from Germany. So unless Andy has access to a personal supply chain ........  :(
Quote from: Entwood on 17 May 2012, 19:40:44
Tried AndyC?
Worth a call, always found him very helpful. He may order 10 but just charge you for what you need?
Quote from: tunnie on 17 May 2012, 19:46:16
Tried AndyC?
Worth a try I guess .. :)
Shackeng
Some of the breakers on here must have a set surely. ??? :y
Quote from: Shackeng on 18 May 2012, 18:46:26
Reply #18 Chris
AndyC has come up trumps .... yet again .. :)
Identified which bolts I have (seems my car is a 2002 model registered in Dec 2001), and which I need, and can get me 3 fairly easily, although it'll take about 7-10 days.... maybe less.
I'm in no rush, those we put in will hold for a while, as long as the "right" ones are in before I tow to France .. :)
Quote from: Entwood on 18 May 2012, 20:29:27
Don`t suppose he could elaborate as to why GM changed them Nige ??? ???
