Author Topic: Is it true??  (Read 6015 times)
Re: Is it true??
« Reply #15 on: 14 May 2012, 17:38:50 »
You need a throttle before you need a dump valve, and diesels don't have them. :y
    • 530D M Sport, 330i Coupe
Re: Is it true??
« Reply #16 on: 14 May 2012, 20:32:29 »
would i be able to fit-
-bigger turbo
-dump valve
-bigger front mounted inter cooler
if so where would i find these and guides and what ever
Bigger turbo= I don't know. Why would you, you'd only get more turbo lag.
Dump Valve= Don't be daft  ;D
Bigger Inter Cooler= You could, because there's lots of room down infront of the rad, but rooting the pipes would be a major problem as there's no way through without major chopping & re-moving of parts.
It would also be a good option if it where possible, because the current set up is a laugh. How in the hell is a Intercooler supposed to work when it's seated behind a radiator & condensor. Air flow, what air flow  ::) ???
If you want more power, you need to remove the cat & the silencer box just after it & re-map it too. It works well with mine :y :y
...and if you want to look after the pump, then add 300ml of 2 stroke synthetic oil to every tankfull of diesel  ;)
waspy
Re: Is it true??
« Reply #17 on: 14 May 2012, 21:17:07 »
 :y :y
custard1
  • southampton
  • its big green and lean
    • 2.2dti
Re: Is it true??
« Reply #18 on: 15 May 2012, 12:14:25 »
Thanks people for all the help and advice. And thanks for bearing with my lack of knowlege about the mig and its dirty lump as this is the first dti i have had
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
Re: Is it true??
« Reply #19 on: 17 May 2012, 23:19:19 »
oi who woke you up lol....you sorted that car yet???...its all rob g  fault anyway.... :y
"The Silver Shed" ?  . . .  I'm  On it mate !    going alright . Trying to sort self Levelling now  :-\ :-\ :-\ :-\ :-\      :y :y
You found another one then? Good to hear mate  :y
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
