Author Topic: Cannister Type Oil Filter.  (Read 3423 times)
Mikes1670
  • Hull
« on: 13 May 2012, 18:13:08 »
Removed the housing for the cannister/cartridge type oil filter to access oil cooler pipes connections. I now need to re-fit but couldn't find a torque value for the cannister type oil filter housing - Anyone know what it should be? ???
Re: Cannister Type Oil Filter.
« Reply #1 on: 13 May 2012, 18:29:54 »
IIRC should be 25Nm, normally stamped on the lid
Mikes1670
  • Hull
« Reply #2 on: 13 May 2012, 18:48:25 »
The lid is stamped with 15Nm but I need the torque value for the cannister housing itself. :y
« Reply #3 on: 13 May 2012, 19:23:56 »
Tight but not rediculously so, just don't swing off your spanner. Isn't it going into a cast block  :-\ so unless you really swing off it you're unlikely to strip anything.  :y
Mikes1670
  • Hull
« Reply #4 on: 13 May 2012, 19:44:17 »
I think I just found the answer - on the maintenance guides to convert from cartridge type oil filter to screw-on filter it states a filter housing torque value of 45Nm - sounds about right to me unless anyone knows different I think I'll go with that :)
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #5 on: 14 May 2012, 06:20:33 »
Canister to block 45 Nm, lid to canister 15Nm  :y
Canister has 12mm in-hex bolt through and a rubber seal between block and canister. Lid has a o-ring which comes with new filter, lid opens with 24mm wrench. For tightening you can also use the 3/8" square in the lid, not much room to get torque wrench with socket on...  :y
« Reply #6 on: 14 May 2012, 08:41:36 »
..... For tightening you can also use the 3/8" square in the lid, not much room to get torque wrench with socket on...  :y
Not really recommended, the lid has a habit of splitting if you do, later lids have had the square removed.  :y
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #7 on: 14 May 2012, 13:14:55 »
For tightening to 15Nm I can not see any problems to use the square...   :-\
« Reply #8 on: 14 May 2012, 14:10:09 »
Agreed, but considering the torque that some of these oil cannisters have been tightened to ............. I think the problem is when they're way over tight & some one tries to undo it using the square.  :y
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
« Reply #9 on: 14 May 2012, 14:45:32 »
yep bastards  >:( !! mine wont even budge with a 3ft braker bar!! so atmo oil changes every 5k until i can get it apart to change filter  :(
