Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: HAS ANYONE HAD THIS PROBLEM  (Read 18233 times)
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
Re: HAS ANYONE HAD THIS PROBLEM
« Reply #60 on: 09 June 2012, 23:17:33 »
Had planned doing mine today ,but as kindly being assisted by a fellow OOF,r decided yesterday to postpone as unsure of weather today.
Just my luck it was the first fully dry day for a week or more so a job that could have been done is still pending.
Hopefully the next few weeks should see it sorted and hopefully new solenoids /fluid and filter should cure mine too.
intresting read intreqed to see the replys
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
amba
  • Medway towns
    • German V6
« Reply #61 on: 09 June 2012, 23:20:11 »
Fingers crossed the replacement 2/3 solenoid does the trick...biggest problem is what needs doing to get at it.
Will post results when changed
Elite_L0ver
  • On too Omega #2
« Reply #62 on: 10 June 2012, 07:56:06 »
Ilet me know the outcome when u changed it and it is in the little sump ain't it  ;D
amba
  • Medway towns
    • German V6
« Reply #63 on: 10 June 2012, 08:40:38 »
2/3 Solenoid lives inside the larger sump ....picture posted up on earlier reply with red arrow.
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #64 on: 10 June 2012, 08:58:41 »
having removed all the solonoids before the hardest problem i found was removing the c lock pins that hold them in HTH :y
amba
  • Medway towns
    • German V6
« Reply #65 on: 10 June 2012, 09:45:09 »
Hi Noel.
Thought a man who wore such "posh socks " would have found no such problems. ;D ;D ;D
Hope your well :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #66 on: 10 June 2012, 10:32:27 »
having removed all the solonoids before the hardest problem i found was removing the c lock pins that hold them in HTH :y  so they are not just a push fit
noel
  • frome somerset
« Reply #67 on: 10 June 2012, 14:24:25 »
not by the way i had to pull them out, i used mole grips to extract them twisting them left to right slowly HTH :y
noel
  • frome somerset
« Reply #68 on: 10 June 2012, 14:38:20 »
pm sent  :y
« Last Edit: 10 June 2012, 14:44:15 by noel »
noel
  • frome somerset
« Reply #69 on: 10 June 2012, 14:41:13 »
Hi Noel.
Hope your well :y
alls well martin ive still got the posh socks, you still got the posh box lol
« Last Edit: 10 June 2012, 14:45:43 by noel »
amba
  • Medway towns
    • German V6
« Reply #70 on: 10 June 2012, 16:14:09 »
I couldn,t afford "posh socks " like those...especially driving and maintaining an Omega  ;D so will just keep the box ...and dream  ;D ;D ;D
Steve B
  • Leicestershire
« Reply #71 on: 18 July 2012, 22:58:17 »
What other symptoms would a damaged thrust washer produce ?
I have normal gear changes almost all of the time ,but every so aften it "hangs onto 2nd " then gives a firm jolt when it engages 3rd.Sometimes does the exact same thing going down the gears.
Will a Tech 2 confirm the solenoid is at fault.
Yep
Steve B
  • Leicestershire
« Reply #72 on: 18 July 2012, 22:59:23 »
no
Pages: 1 2 3 4 [5]  All   Go Up
