Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Head Gasket Talk including ''What's your workshop like''?  (Read 15065 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Head Gasket Talk including ''What's your workshop like''?
« Reply #45 on: 18 May 2012, 20:41:18 »
will be about 10 of them
so presumably quite visible when camshafts out?  :y
RIP Paul Lovejoy
martin42
« Reply #46 on: 18 May 2012, 20:43:31 »
yes mate  :y
Webby the Bear
  • Northampton
« Reply #47 on: 18 May 2012, 20:50:05 »
cheers mate  :y
RIP Paul Lovejoy
« Reply #48 on: 18 May 2012, 21:50:39 »
The cam shells need to go back in precisely the order they come out.
Webby the Bear
  • Northampton
« Reply #49 on: 18 May 2012, 21:53:16 »
Are they the things that i initially circled (in green)?  :y
RIP Paul Lovejoy
« Reply #50 on: 18 May 2012, 22:04:34 »
You circled the bolts that hold them in place. They are, in effect, the clamps that hold the cams down
Webby the Bear
  • Northampton
« Reply #51 on: 18 May 2012, 22:06:51 »
cheers mate  :y
RIP Paul Lovejoy
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #52 on: 18 May 2012, 22:44:53 »
they are marked up on the sides, left as L, right as R. keep them in order & you wont go wrong.
8 head bolts. in each head.  :y
Webby the Bear
  • Northampton
« Reply #53 on: 18 May 2012, 22:52:22 »
cheers RB. Looking forward to it  :y :y :y :y
so the bolts. if this was my own car i'd obviously replace as per twiglet's post. but as ralf is a practise car can i get away with using the old ones?
RIP Paul Lovejoy
The Red Baron
« Reply #54 on: 18 May 2012, 22:56:39 »
are you fitting new head gaskets?
if you are, then new is a must, if not then its a risk they will snap on tightening. but then the gaskets will be fubbered anyway. ???
« Last Edit: 18 May 2012, 22:58:45 by The Red Baron »
Webby the Bear
  • Northampton
« Reply #55 on: 18 May 2012, 23:00:13 »
no mate, want to just remove and replace to practise the job  :y
RIP Paul Lovejoy
The Red Baron
« Reply #56 on: 18 May 2012, 23:02:29 »
ahh ok, you know it wont run again dont you.
Webby the Bear
  • Northampton
« Reply #57 on: 18 May 2012, 23:09:10 »
really??  ???
RIP Paul Lovejoy
Webby the Bear
  • Northampton
RIP Paul Lovejoy
« Reply #59 on: 19 May 2012, 09:35:05 »
really??  ???
Yeah, compression will be shot, and it will piss oil and water everywhere.
If you want engine to run for now, do HG last.
Quite expensive to actuall replace HG fully - HGs, bolts, exhaust gaskets, coolant bridge washers, transfer pipe o-rings etc
Pages: 1 2 3 [4] 5  All   Go Up
